I replaced the cuplin between the motor and the transmition on my kenmore 20722. when i put it back together and tried a test run the water doesn't stop running. what did i miss?
  • 5,911 Answers
There is a small air hose that attaches to the pressure switch inside the operator console. It is common for this hose to come loose when disassembling the washer. If the hose is not attached properly, the pressure switch will not sense the pressure differential in the wash tub basin as it fills and will not be able to shut off the water. The following link explains:
http://www.fixya.com/support/r3575901-washer_overflows
Check the entire length of the air hose that runs from the pressure switch to the air dome on the lower right hand side of the wash tub. Make sure it has no leaks, cuts, tears, holes, or....is not clogged.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Aug 04, 2010
I need an owners manual for troubleshooting for a kenmore 70 series model 110 20722, serial CK4011186, type 111 When it spins out the wash water and rinse water not all of it goes out? Does it have a...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Based on the 20722 Stock Number, the following might be the Sears diagram site for your washer. Check under the Lid for the exact model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Two possibilities:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
These models don't really have a filter but I'd check the hoses to and from the pump and inside the pump to look for any obstructions in addition to the Motor Coupler (about a $20 part) and the clutch.
Jul 01, 2010 | Kenmore Washing Machines
Doesn' drain, when trying to spin, get loud buzzing noise, like motor is jammed
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 20, 2010 | Kenmore 20722
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Machine will barely agitate if at all
check motor,capacitor(if have),or black lead brush on motor
Feb 16, 2009 | Kenmore 20722
Kenmore washer not spinning or agitating
hi thanks for the question don't take back off please. the problem is with the motor coupling located at the motor & transmission to repair . 2 screws at console .remove .lift console .remove 2 brass clips disconnect wiring plastic disconnect pull cabinet towards you .put a block under left front lift up remove the pump 2 spring clips .remove motor wireing . remove the motor replace the motor coupling thanks the appliance doc
Sep 06, 2008 | Kenmore 20722
Kenmore Lid Switch Bypass Test
put a jumper wire from blue to pink
Jul 07, 2008 | Kenmore 20722
Kenmore - tub does not spin
motor coupler 20 bucks from the repair store 285753a is the part number i believe gl
Mar 21, 2007 | Kenmore 20722
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
