Question about Garden
It wont start at all! - Garden
  • 7,482 Answers
Pull your spark plug out and make sure you are getting spark, if you are then:
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Polo 2001 1.9 ssdi wont start fuelfilter/belt/fuelpump all done ecu was wet dried out wont start
Have you run basic tests? Spark at plugs? Correct fuel pressure at key on? Compression?
Mar 27, 2016 | Cars & Trucks
Why wont my 2005 ba ford falcon start?
Have you changed the fuel filter?. Have a fully charged battery if the cranking voltage drops below 10 volts the computer can't work and it wont start.
Aug 11, 2014 | 2005 Ford Falcon
Won't start won't turn over or do nothing put new battery still wont turn over wont start
No one can help you much if they do not know what year etc. your bike is. WHAT DTCs are set??
May 04, 2014 | Harley Davidson FLHX Street Glide...
Wont start, service start system
blow fuse
check all fuses first with a meter.
what engine?
what transmissin, A/t or M/T
do you mean wont crank
or
cranks fast and robust but will not start
no a/t car starts if not cranked.
Mar 19, 2014 | 2010 Suzuki Kizashi
Wont start, but it will turn over
this doesnt make any sense wont start but it will turn over then u say it starts but wont kick over??? hmmmmm do u have gas in it?
Jan 05, 2014 | Cars & Trucks
2005 camry starts fine then wont start jump start okay for a day a month maybe then wont start
This behaviour is typical of worn starter motor main contacts, at the bottom of the starter solenoid.
Feb 25, 2013 | 2005 Toyota Camry LE
Wont start
if i drive my bronco to work shut it off it wont start sounds like it has a dead battery if i let it sit for an hour it will start back up can you tell me if you know what it is
Dec 15, 2008 | 1989 Ford Bronco
WONT START
check the ignitionswitch or the main relay
Sep 26, 2008 | 1994 Honda Accord
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
