Question about Canon CB2LW (0763B001) Battery Charger for NB2LH
How can I tell whether the lithium ion battery is kaput or not? It shows a green light in the charger, but the camera doesn't work.
    Novelist:
  • 178 Answers
The best approach here is to buy a new battery, make sure you are buying the manufacturer suggested battery and not a look alike, yes it will make a difference due to voltage differences and similarities.
if that doesn't work, then you can assume your camera has a problem.
Teleplan Camera Repair does a very good job.
Be sure to send in your battery or batteries and label them old and new, they will test them and advise on voltage levels and let you know.
http://www.teleplancamerarepair.com/
Posted on Aug 04, 2010
Lithium ion battery does not last as long
There is no such thing as a memory system in your battery. If you charge the battery until the green light on the charger comes on, that is as much as the battery can/will safely charge to. With Lithium batteries, they will fully charge whether they are at 75%, 50% or 10% capacity when placed on the charger and discharge to 0% if you use them that long. If you need the battery before the green light comes on and you use it, it will still fully charge when replaced on the charger. All batteries do discharge at different rates. Most not noticeably but a few will discharge fast enought to be noticable. If it affects your usage of the tool, you may want to exchange it or get it replaced under warranty because it will only get worse with age.
Mar 03, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Are all the Lithium batteries working like this. Mine work for a short time then stop dead. Wait a while then they will work again. Really a pain when you are working trying to do somthing and have to run...
I use the Ryobi Li-Ion tools the L-I batteries will cut off when they get to a low charge level this is to protect the batteries Li-Ion batteries life span is shortened when fullt discharged so when the tool suddenly stops put the battery on charge,also if the battery has a charge indicator light for a more accurite idea of the charge (green is charged,red discharged) hold the test button on then run the tool the light may go from green to red if it does that shows the the charge is about depleted if the light stays green you have a little run time left.
Oct 25, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
My 18 volt Ryobi battery shows charged in charger (Green Light) But will not work in any of the power tools. I have three other Batteries that do work. Bought at Home depot on july 24 2011 Ryobi Two 18V...
Some of batteries drain very quickly. Depends on how they are used.
Feel free to check Your Local battery Manufacturer for best prices for all different batteries. You name it and they have it or they can custom make a battery for you.
Thanks
Oct 09, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger I can't get these to work! The charger does what it should but when I have a steady green light the batteries do not power my drill, when I...
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Jan 16, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
I have a new Ryobi 18V Drill which came in a package from Screfix with two batteries. I charged one of the batteries to start with and when the green light came on I used it and immediately charged the...
Take it back to the store and tell them it is no good, and get a new pair of batteries, take the charger too. I had the same thing, brand new batteries, gone in weeks, they replaced them, no problem.
Feb 21, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Why is the yellow and green light on when i put my batteries.
try and unplug the charger for a couple minutes and let it reset and the insert the battery. It might work, I have a LI-ION charger from a different MFR that does the same thing and it works for me If it doesn't work I would suggest calling ROBI direct at 1-800-525-2579 and speak with their tech department. They don't provide much online help.
Oct 14, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi battery charger with a solid yellow and solid green light
I was recently told that the lithium ion does not like cold temperatures so you may need to bring the batteries and charge into a warm location and wait until they reach a warm temperature and then charge them.
Feb 25, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Kodak Z812 shuts off automatically
It is a high-powered camera, also knows as a GREAT camera. Use CRV-3 lithium duracell batteries. I have the same camera and the same "problem", but when I use that battery it lasts forever.
Dec 03, 2008 | Kodak EasyShare Z812 IS Digital Camera
Canon CB2LW (0763B001) Battery Charger for NB2LH Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
