Question about Troy Bilt 5.5hp Self Propelled Mower
How to clean carburetor on troy bilt self propelled 675 series mower
rycgl
  • 1545 Answers
SOURCE: where is the carburetor on
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Posted on Apr 13, 2011
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
Posted on May 30, 2010
witserv
  • 144 Answers
SOURCE: ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS,
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Posted on Jun 14, 2010
  • 251 Answers
SOURCE: My Troy Bilt self propelled
Hi , it can often be something as simple as the engine needing a oil change as oil looses viscosity/thins with use ( use correct grade ), replace or clean the oil filter and a good service or something more complex which requires a full engine stripdown like worn piston ring/oil scraper ring causing oil to flow up the cylinder walls and fouling the combustion chamber or oil leaking up through the valve stem oil seals , also storing the machine tilted can cause oil to collect in the chamber or petrol to leak into the sump causing the oil to thin.
Hope this helps , please rate accordingly
Posted on Aug 31, 2010
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 675 Series manual
Try internet search w/full detail like you used in question plus specifics like model number. That worked for me w/my lawnmower manual search.
Jul 09, 2012 | Garden
Need owners maual
Contact Troy Bilt directly and request one.
Jan 09, 2012 | Craftsman Garden
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Troybuilt 675 hp lawn mower doesnt start
self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
1,185 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
