Question about Dometic Rooftop RV Air Conditioner
Dometic Duo Therm, 15000 BTU: Thermostat works, fan runs, but no cool air. Any ideas?
Our domrtic air and furance will not come on at all. No clicks when we try the theranstat Dometic told us to unplug the thermonstat but do not know where it is located. we have an anolog thermonstat . Also any other thing that might help me to troubleshoot, we live many miles from dealer.
Posted on Aug 05, 2010
  • 674 Answers
Check the compressor and the condenser fan to see if they are running;they will have to be checked from the roof. If one is running and not the other then check the capacitor for the one that's not. If both are off then check the contactor that controls them. You will also want to make sure they are getting power. If they have power and the capacitors are good, check the motor windings for the fan and compressor. Hope this helps. Let me know what you find.
  • Brian Niten Aug 06, 2010
    To eagles8, do you have power to the unit? Check the circuit breaker or fuses.
    eagles8, also look in the control panel inside for a small fuse.
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
Why am I not getting power to ac capacitor?
A thermostat or a relay activated by the thermostat turns power on to the capacitor for the compressor.
May 03, 2015 | Dometic 459196 Duo-Therm Brisk Air...
How do I Wire a duo-therm RV heat pump
see wiring on panel make sure dip switches correct
Feb 26, 2015 | Dometic 459196 Duo-Therm Brisk Air...
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
Duo therm runs cools clicking
Sounds like a reversing valve solenoid.
Feb 23, 2012 | Dometic Rooftop RV Air Conditioner
Have a Duo Therm 59516.531 15000 BTU blower motor does not run checked cap 5mf ok tried direct power still nothing any thought. thanks
if you tried direct power and still nothing then your fan needs to be replaced . there should be a a/c supply store near you . get the model - serial number on the fan or the unit itself to get the right fan for your unit . hope that helped
Jul 01, 2010 | Dometic 57915531 Air Conditioner
Duo Therm Thermostat anticipator adjustment
replace your thermostat with a cheap digital heat/cool thermostat - no more problem. (be sure to turn off the power to all parts of the HVAC system before changing the thermostat.)
May 28, 2009 | Dometic Rooftop RV Air Conditioner
No power to thermostate on Duo Therm 15000
Look for a small fuse somewhere in the control panel. Usually a blade type (car) fuse 3 to 5 amp. Chack to see if its blown. If you have no fuse, or its NOT blown. Check to see if you have voltage comming out of, and going into the transformer.
Thsi is where you would START to diagnose the problem. Check this and we can go further.
Jan 18, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
355 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
