Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Will not dispense water on rinse cycle - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Upholstry brush will not dispense water, the suctin works and the floor cleaning part all works.
Posted on Aug 07, 2010
Leaks water or cleaner when setting upright
Turn the setting knob to the rinse cycle when not in use, and you have leftover cleaning solution. This is the standard setting when storing , it blocks the soap from dispensing.
Empty the water tank and rinse after each use, and store empty.
If still leaking check the lid on the soap dispenser, make sure the gasket is even before tightening down and or the gasket between the water tank and the body, make sure they seal , check if they are straight and flush where they connect..
Mar 17, 2014 | Bissell 8910 ProHeat Clear View Upright...
F7210-900 Steam Vac. will not put out water when switch is in wash position but it will put out water when the rinse position
There are two electrical solenoids inside the hood assembly. One opens to dispense rinse water, and the other dispenses the soap and water solution. It is likely that the soap and water solenoid has failed and will require replacement. A "work around" fix for this is to mix the soap solution in the clear water tank ( 5 oz. of shampoo per gallon of water ), and shampoo that way until the solenoid can be replaced.
Mar 15, 2011 | Hoover Vacuums
Water wont come out
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 21, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
The water is not coming out to clean the floor
Your unit uses water, correct? I have a Proheat 2X and it wouldn't dispense water. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 21, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
No sign of water movement from cleaning heads
My Bissell ProHeat is not dispensing water thru the floor cleaning position. I get water flow thru the tool application. Any ideas???
Apr 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell pro heat 2X has stopped dispensing water from the tank, the suction is working and it seems to be dispensing the detergent, so it is not rinsing or washing with water. I have cheaked to see if...
Apr 19, 2010 | Vacuums
It won't dispense water or suction it up
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
Apr 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
No water/cleaning solution comes out on wash cycle
With this model, the soap dispensed is controlled by electric solenoids. these can be tricky to troubleshoot. I would take it to your nearest dealer. these solenoids fail, and cause a variety of symptoms.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 08, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
160 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
