Question about E-Machines emachines (emachinees) CD-ROM Drive
Cd rom does not fit on spindle on computer. - E-Machines emachines (emachinees) CD-ROM Drive
The cd is stuck in the drive
unfortunately those cd drivers there is only 1 way to get the cd out when the drive has become faulty and thats by opening the computer up unscrewing the drive and removing the rom drive casing to manual move the spindles to eject it.
Mar 12, 2014 | Gateway ZX6900 All-in-One Desktop Pc
I need to know how to set up new hard drive after fitting please
do you know how to go to setup section as computer opens?
Some computers you press DEL key others F2 others F10
when computer is just starting.
go there and confirm the disk is visible to hardware.
In the same location ensure you can see cd/dvd ROM
in the same location make the cd/dvd ROM to be first when starting up computer.
save changes if need be.
put your cd/dvd ROM with starter operation system (assuming windows)
and load your computer.
Aug 04, 2011 | Packard Bell Computers & Internet
The computer is detecting the CD rom but the cd rom is not detecting or reading any CDs
The laser is probably burned out or the spindle motor isn't turning.
With the price of these units, I'd just replace it.
There's not much you can do to fix either problem anyway.
A CD ROM (hard to find, but some places still carry them) can be had for $5 or $10.
For just a bit more, you could get a DVD burner.
Mar 17, 2011 | Sony (CDU701) Internal 32x CD-ROM Drive
Dvr cd drive won't play cds get message asking to insert a disc when one is already inserted
Your cd drive is damage, the laser head or the spindle is not functioning and is not reading the disc thus causing the message of no cd being insert to appear, however the cd-drive power is still working which the computer is able to still detect, but like I said earlier the spindle/laser head is malfuction. You will need to replace the entire cd rom drive. If you don't know how to replace it, an external cd/dvd drive will also do the job.
Jan 30, 2011 | Dell Inspiron 531s Desktop Computer
I put the CD in CD-Rom the i went to my computer to open the CD but it say "Please insert the disk". Help? I think the CD work in DVD-Rom?
Some disk can be manufactured bad. Simply try another disc & check. If that too fails, then most probably the lens in the CD ROM has failed - better buy a new one.
Dec 01, 2010 | Maxell CD-R 80 Minute 700MB Media...
My laptop is not detecting cd in it wht to do???????????
connect an external cd/dvd drive & see if its working or not. If yes, then you need to replace cd/dvd drive of your laptop.
Jun 16, 2010 | Acer Extensa 4620 Notebook
I want to use the scan fuction, and am told to load cd rom. I have a acer 5315-2808 computer and the cd rom does not fit the spindle of my cd reader.
Your computer can not scan on its own, you need a scanner, you need to install the scanner with the cd that came with the scanner or post the brand and model and I will see if the software is available online.
Oct 13, 2009 | Acer Computers & Internet
The cd-rom drive in my computer has stopped working all of a sudden. The cables inside the tower are all connected however it does not recognize a disc being in the cd-rom drive! I also get a warning that...
Replace the Cd-rom drive, sounds like you may have a bad spindle motor and or Laser assembly. Cd-roms are very cheap these days, and you might consider replacing it with a DVD drive instead, which is downward compatiable.
Sep 28, 2009 | Gateway GM5084 PC Desktop
Not recognising dvd player/not playing dvds
Sounds like the laser pick-up is not reading the disc, or the spindle motor is not spinning so the dvd can be read.
Jan 25, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
CD ROM Rubber Ring
Get a new one from any electronic parts selling shop. It's cheaper as anything.
Aug 31, 2007 | Sony CDU5211/5221 Internal 52x CD-ROM...
Computers & Internet Logo
127 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
