Question about Brother HL3070CW Compact Digital Color with Wireless Networking Laser Printer
I'm installing my new Brother HL3070CW color Laser printer. I am using a Mac, the box and literature for this printer state it works with Mac. Going through the wireless Device Setup Wizard gives me an error "NO Devices found on your wireless network" I have the new printer hooked up to my AirPort and have tried refreshing several times, I've used 2 different Macs on my network and nothing helps. The only other variable is my network cable, but this is a new cable it hasn't been used for anything, it just sits with my Airport for times like this.
    Habit-Forming:
    New Friend:
  • 177 Answers
You must have the print drivers installed on you Mac.
Posted on Oct 22, 2017
Darbsus
  • 47 Answers
SOURCE: stopped printing PDFs and Web pages
those your printer support wireless printing? if not try to check if it is bluetooth capable
Posted on Mar 11, 2008
SOURCE: Does HP laserjet 1020 work with Airport Express
I removed any printer configurations for this printer in both my pc and my mac (both usb and wireless). Then I restarted both computers and added the printer via usb again to each. At that point I went back to the extreme configuration and under the printers tab it was finally seeing Hewlett Packard Laserjet 1020. After that, adding via Bonjour went smoothly on both platforms.
Posted on Oct 18, 2008
SOURCE: Connecting printer
1. Unplug the cable.
2. Hold the Go button for 10 seconds until the network config page is printed.
3. plug the cable and try it again.
Posted on Nov 07, 2008
winxpmain
  • 14 Answers
SOURCE: Canon Pixma MP160 Scanner on 1.83GHz Intel Imac running OSX 10.4.9
GET YOUR SOLUTION DIRECTLY FROM CANON. VISIT
www.canon.com/printer/prob3178hgu8/solution
121
Posted on Dec 15, 2008
SOURCE: BROTHER MFC-6490CW won't connect to wireless router
have you found a solution? I just purchased brother wireless printer, same thing, called and they said it must be my router. I haven't had a chance to play with it as much as you have, but before I do was wondering if you found a way to make it work yet?
Posted on Jul 20, 2010
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Jun 16, 2017 | Brother Hl3070cw Hl-3070cw Color Laser...
I have a Brother HL-5140 Laser Printer and the Orange light comes on and when I go to the print queue to print something, it states the printer is offline, how can I get it back online?
Try installing the software package that comes with the printer. The software usually loads a helper app that pings the printer and keeps it online.
Apr 13, 2015 | Brother HL 5140 Laser Printer
I have a vertical strip about 3/16" wide about 3/4" from the left side of the page that will not print in the black only. I have replaced the black toner and black drum unit, and it is still there.
The LED Assembly LU5831001 is probably bad. This machine has 4 LED assemblies mounted in the top cover. It doesn't use a laser scanner.
To troubleshoot, you can clean them, then swap them between colors before you buy it.
25296363-yargu4yf5zncljh0zgcte5yj-3-0.png 25296363-yargu4yf5zncljh0zgcte5yj-3-2.png
Nov 24, 2014 | Brother Hl3070cw Hl-3070cw Color Laser...
PRINT UNABLE 1A
Print unable 1A indicates condensation forming inside the machine. If the condensate drops on to the main circuit board (positioned just under a metal bar that acts as a moisture condenser) you have a terminal fault. If your machine is still reporting a 1A error after two weeks in relatively dry conditions, it is probably all over bar the burial ceremony.
Feb 01, 2012 | Brother HL3070CW Compact Digital Color...
Printer telling me to replace drum. I replaced all the colors and still not working
you need to reset the counters so the printer knows there is a new drum.
to do so try this:
Turn the printer power switch back on.
Press + or - to choose "Machine Info.".
Press OK to proceed to the next menu level, and then press + or - to choose "Reset Parts Life". Press OK, and then press + to choose "Drum Unit".
Press OK, and then press + or - to choose the color that you replaced.
Press OK two times.
Sep 18, 2011 | Brother HL3070CW Compact Digital Color...
Our brother printer wireless hl 3070cw will not print, it is telling us that it is ready but will not print
it would have print archive in its job print .. check and delete . or install printer again .
i hope it shall work .,
Mar 29, 2011 | Brother HL3070CW Compact Digital Color...
I am getting a replace magenta cartridge message but have only printed about 300 pgs most of which were only b&w
The full replaement color cartridges for this printer only print 1,400 pages @ 5% coverage. If you are speaking of the starter cartridges (the ones that came with the printer) they only have about half of that. If you print with this machine in full color mode, which is the default, it counts developer revolutions even if you only print b&w. If this is a purchased toner cartridge you are speaking of, you can reset the flag gear on the side of the cartridge in order to get more prints out of it, put the print quality may not be good. To extend the life of the color cartridges when you are only printing b&w, set the printer properties to print in "graysale" or "monochrome" under preferences. When you try to print a document, in the dialog box next to the printer name click preferences. Look on all of the tabs for one of the selections I mentioned and select it. This is an expensive cost per page printer, and you may not want to use it for all of your prints. It may be adviseable to get a cheap monochrome only printer for your b&w needs and only use this brother machine for your full color prints.
Sep 30, 2010 | Brother HL3070CW Compact Digital Color...
My Brother MFC-9840CDW won't print color any more. Error alert: "Invalid format for short nickname". Please help me fix this.
I assume you are running snow leopard on a MAC.
Please click on the link below and download and install file, this should resolve the issue.
Mac printer drivers.Brother printer drivers for Mac 10.6:
http://www.apple.com/downloads/macosx/apple/firmware_hardware/brotherprinterdriversformacosxv106.html
Mar 31, 2010 | Brother MFC-9840CDW Laser Printer
I need to download the drivers for my Brother HL-2040
There is no Mac driver available for this printer. But you can follow the steps to install your printer for Mac
http://pub.brother.com/pub/com/pdf/macosx/mac105_driver_usb.pdf
Sep 09, 2009 | Brother HL-2040 Laser Printer
Stopped printing PDFs and Web pages
Jan 09, 2008 | Brother HL 1440 Laser Printer
Brother HL3070CW Compact Digital Color with Wireless Networking Laser Printer Logo
203 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
