Question about NorStar M7208 Corded Phone
Our office has a combination of Norstar M7310 and Norstar M7208 phones. One of our M7310 phones died today and I wanted to trade it out with a M7310 that was in my office. I followed how to turn off the relocation so it would adapt to its new location. It has turned into a real mess as now the phone in my office rings and it does not ring where the receptions is. The phones are also confused as to their location. I just want the phones down stairs to ring and the one up stairs not to ring. How can I engage and disengage this feature? Please make your message simple as I am a novice at this. Thank you -jwhite@mvlc.org
  • 105 Answers
Dial "F * 0" (Feature, star, zero), which is Button Inquiry, and press an intercom button to see the extension number of the telephone. If Set Relocation is set to "Yes", then the extension number & mailbox will follow the phone when it is moved. Move only two phones at a time, and wait until they completely "boot-up" before moving additional phones.
Hope this helps.
Posted on Aug 05, 2010
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
My Norstar M7310 is stuck in handsfree mode. Is there a feature or programming fix for it?
Nothing in programming typically would help with exception to maybe swap by plugging in a M7208 into your problem jack then swap back to m7310 again. Going to 08 and back to 10 can sometime clears issues otherwise sounds like a bad phone and needs repair.
Oct 03, 2012 | NorStar M7310 Corded Phone
Handset test on meridian norstar M7310 / M7208 / M7100
Feature 805 is valid on versions 2.0 or above.
Jul 07, 2010 | NorStar M7310 Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
NORSTAR M7310 Needs to swap primary line
To find the programming codes for your phone, click on this link.
http://tiny.cc/U3cIt
If this doesn't help you can
Call a Norstar Service Technician
800-527-4663
Feb 02, 2010 | NorStar M7310 Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Sep 21, 2009 | NorStar M7208 Corded Phone
I'm looking to rotate phones around the office so that they can remain with their employee. Basically, I want to plug in the original phones to another line and reprogram for the original extension with...
In my workplace, when you move the Nortel M7100 phone, the programmed info (extension number, etc) moves along, just like if I was rewiring all phones. Have you tried just to unplug the phone and plug it on the new location? Here the extension number moves along with the equipment... (Nortel Norstar M7208 and M7100). Good Luck!
Jul 02, 2009 | NorStar M7310 Corded Phone
Cordless phone
Just about any one will do IF you get an Analog Terminal Adaptor made for your system. The ATA requires programming in your system, so it's probably best to call a Nortel service tech.
Before some smart sould points out that Nortel has a digital cordless, remember that the "T" phone doesn't work on a Compact 308 box. Besides, an ATA and a $50 cordless is WAY less expensive.
Carl
Jun 27, 2009 | NorStar Meridian M7310 Phone
Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
Dec 14, 2006 | NorStar M7310 Corded Phone
NorStar M7208 Corded Phone Logo
313 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
