Question about Vivitar ViviCam 5018 Digital Camera
I insert memory card, and camera says sd card not ready, change to internal memory. how do i make it work?
    Novelist:
  • 178 Answers
This little SD card has a sliding button on the side, make sure it is set to unlock.
Posted on Aug 04, 2010
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a...
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
May 28, 2011 | Cameras
I inserted an sd memory card into the card slot and it still records directly onto the internal memory. How do I get it to record directly onto the sd card?
With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. After that, insert your card and it should work.
Apr 26, 2011 | Cameras
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Won't read memory card
This usually indicates that you are trying to use 'newer' SDHC High Capacity cards of 4GB or more. Older and cheaper units like this Vivicam 5024 unfortunately may be limited to 2Gb 'standard' SD cards.
Hope it helps: let me know what cards you are trying to use.
Jan 16, 2010 | Vivitar ViviCam 5024 Digital Camera
I try to put sd memory card in and it say's card inserted
First, be sure the slide switch on the side of the card is in the unlocked position. A new card must be formatted in the camera before using to work properly. This will erase it so download any pictures still on it using a card reader if necessary.
Jan 04, 2010 | Vivitar ViviCam 5018 Digital Camera
Sd card cannot be read & internal memory of camera cannot be read
Which Kodak camera model?
It may not support a large SD (SDHC) memory card.
Remove the card and remove the batteries.
Turn ON the camera (I know, no batteries) for one minute.
Turn OFF camera and install batteries.
Do not insert the memory card.
Does the internal memory work?
If so, insert memory card.
If it's ok to format the card, do so.
If not, then use a USB adapter and copy the memory card to your [My Pictures] folder.
Format memory card.
Oct 01, 2009 | Kodak Cameras
Card protection on wii not take pictures
I assume you mean the card protection on the SD card??? Turn off the camera, pop out the SD card, slide the little switch on the side of the SD card from locked to unlocked, re-insert the card the way it came out, and turn the camera back on. If it still doesn't work, take thed batteries out, reinsert them, then turn it on again. It should be ready now to record onto the external memory. If it still doesn't, get the manual out and check on transferring fiels from internal to external memory.
Feb 27, 2009 | Polaroid T730 Digital Camera
Genius G-Shot HD55 (camera) - How to get SD card working??
For Genius G-Shot HD55 you need to insert the SDHC card deeper into the slot until it clicks closed, like opening a pen, then when you want to remove it press it again until it clicks to release, like closing a pen. Your card is recognised after the deep click insertion and restarting the camera.
Dec 13, 2008 | Genius Cameras
Internal memory to sd card
I don't know your camera; but... Before we assume anything about your camera we should check that SD card in another SD device that we know is working. your camera should default to the SD Card like most devices, which are able to use both simultaneously. It seems likely that something might have happened to the SD card if that is the only one you have tried in your camera. food for thought
Aug 28, 2007 | Kodak EasyShare CX7525 Digital Camera
SD CARD
If I remember correctly, when you insert an SD card, it "hides" the camera's internal memory. There should be an camera option for copying the files from the internal memory onto the inserted SD card. If not, you could try connecting the camera to your computer with the SD card removed, in order to access the files in the internal memory.
Feb 10, 2007 | Samsung Digimax S500 Digital Camera
Vivitar ViviCam 5018 Digital Camera Logo
320 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
