Question about Mitsubishi WS-55807 TV
Where can I get a module and ic for a mitsubishi ws55807 projection tv?
  • amanda312 Aug 05, 2010
    We had someone come out to look at it and he said it needed a new module and he could get one for $400 (more than I want to spend), part# 930k864001. I was wondering if refurbished ones were available since he mentioned we would have to send the old one in.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If you are talking about convergence, this model uses 2 of the STK-392-570 convergence IC's which are located on the middle circuit board.
The board has not been available for a long time and one seller on Ebay has the chips at about 14 dollars for a pair.
Repair requires removal of the middle board and the chips are soldered in.
I do have start to finish, step by step instructions for this repair in this model; they tell you everything you will need and how to do the repair, I can post them here for you if you want them for free.
Considering that even if the board was available it was well over 100 exchange it is much cheaper and better to do it yourself.
Let me know if you have questions or concerns.
SD TECH
Posted on Aug 04, 2010
  • SD Tech
    SD Tech Aug 09, 2010
    iF THE PROBLEM IS ON THAT BOARD HE IS NOT GOING TO SEND IT OUT---HE WILL REPLACE THE CONVERGENCE CHIP ETC AND HIT YOU FOR 400 FOR A 200 DOLLAR JOB THAT SHOULD BE ABLE TO BE DONE RIGHT IN YOUR HOME.
    sd tech
  • amanda312 Aug 10, 2010
    If I can find the module then he will come out and fix it for no extra charge (we already paid for the service call and there is no hourly charge) but the module he found is $400 and I can't seem to find one at all.
I have a Mitsubishi WS-55809 projection TV. The convergence will not ajust using the user controls and the picture looks bowl shaped in every format.
you will need to install a convergence repair kit for your model. You can get the repair kit called the " WT46807, WS55807, WS65857,WS65907, WS73907 WT46809, WS55809, WS55819, WS65809 and WS65819 Convergence repair kit " which has the parts and the CD with instrucions. Its available at the following link http://tvrepairworld.com/mitsubishi_repair_kits
Feb 07, 2013 | Panasonic PT-56WXF95 56" Rear Projection...
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
MITSUBISHI WS55807 NO PICTURE HAVE SOUND AND CHANNELS
It may be the closed captioning it happened with mine. I simply turned off the CC on the TV.
Apr 08, 2010 | Televison & Video
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
Ws55807
hi
your convergence circuit has started giving trouble .... normal thing after a few years running for projection televisions ...... could be that the convergence IC's are getting too hot (two big IC's on a heast sink bearing an STK number on it) or that you have some loose soldering that needs to be resoldered on them.... worth the check
or have your power supply circuit board checked, if nothing seems wrong trouble leads to your horizontal deflection circuit board.
regards
May 28, 2009 | Mitsubishi WS-55613 55" Rear Projection...
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Oct 05, 2008 | Mitsubishi WS-55807 TV
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
Mitsubishi ws55807
I had this problem and corrected it by resoldering all 36 pins of the 2 convergence IC's. Biggest problem was getting the circuit board out far enough to prop it up and get underneath and get at the solder connections, required unplugging a few cables, 3 screws holding it in. Works great now, I used to fix it by taking the back off and banging on the Heat Sinks which house the IC's, I could tell then that it reacted like cold solder joints. I decided after a field service guy charged us 95.00 for a service call and quoted 650.00 for a repair. Hope this helps someone.
Nov 05, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
