Question about Garden
Mower starts when clutch/brake is pressed but dies when depressed.
    Brigadier General:
  • 3,911 Answers
I would examine the safety switches and the relay to which they are connected. Seems to be a common problem, especially on the Sears
units.
Posted on Aug 05, 2010
Scotts 1642h riding mower Ignition Switch, Seat Switch or Wiring Problem?
Will run with no one in seat if clutch is depressed but will not run with clutch depressed and blade engaged with no one in seat. Could be your pto safety switch is bad. Maybe battery new but not charged try charging with 2 amp charger overnight and see if that helps. Maybe diode in charging circuit bad.
Sep 07, 2017 | Craftsman Garden
Engine dies when the clutch is let out on riding mower
check the safety switch on the clutch/brake pedal
Apr 10, 2012 | Garden
My lawn mower will start easily and continue running as long as the clutch brake is depressed but when I lift the clutch or try to engage the blades while the clutch is depressed the mower will stall.
This is a shot in the dark. I think you have a failed "operator presence safety switch". Rule this out by finding the switch and jumping it.
Your mower should run with no one in the seat IF THE PARKING BRAKE IS SET.
If the brake is released and no one is on it, it should shut off.
If you are on it and the brake is released you should be able to engage the blades (probably an electric clutch)
Purpose of this interlock is the shut the machine OFF should you fall off or jump off the machine. Do not disable this valuable safety feature.
Let me know what you find.
Thanks for your question @ FixYa.com
May 15, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I went to go mow the lawn for the first time this season. Tractor started right up. took the deck cleaned and greased it. Went to engage the p.t.o. for the mower and the tractor stalled. Can't figure...
Hi and welcome to FixYa, I am Kelly.
The power sequence for engaging the blade deck is. Clutch brake pedal depressed, operator in seat, Enage selected and brake pedal released. When the blade enages the engine igniton kill wire is routed through the seat switch AND the PTO clutch. If either the PTO Clutch or the seat switch has a problem the engine dies. Same goes for the clutch brake pedal switch... if the clutch brake is not coming all the way up the engine will die.
If you respond with a model number (example LX2000) I can show via a manual where you need to troubleshoot using a meter.
Do a couple of good bounces on the seat, check the clutch brake pedal switch for clicks and then attempt to an engagement.
Also inspect the PTO clutch wires and connectors for corrosion.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | Garden
On a husqvarna gth2448 engine dies when letting up on brake pedal
Do you mean the engine dies when you place a load on it? As in letting out the clutch/brake so the engine has to work by moving the mower, or in engaging the blade clutch so the engine has to spin the blades?
If so these V-2 engines have a propensity towards bent valve push rods, as did my 2148, which can knock one cylinder out but still run so long as little or no load is on the engine.
If not a power issue, then I would look to an electrical problem. I think you have to depress the pedal to start, must be a switch there somewhere activated by the pedal position which could be bad.
Mar 09, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Engine dies when brake is released
check if the switch for the blades or the brake is not releasing.
Jul 04, 2009 | Garden
Motor dies when engaging the cutting blades
I need help with this exact same problem. Someone please answer this question.
May 22, 2009 | Craftsman Garden
Mower starts, but when I let off clutch, it dies.
Grass and debris clogg the switch mechinisms, safety interlocks are sometimes a pain to diagnose but I would first look at the seat interlock, the petal switch and ffinally then the mowing deck.
Dec 24, 2008 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
