Question about Kenwood DNX5120 DVD Navigation System GPS Receiver
I just bought a car with a ken wood dnx210ex gps nave system. It works great but the display for the radio/audio does not work. Is there something I can do?
2 Suggested Answers
MrMojoRisin1
  • 412 Answers
SOURCE: ken wood car music system
codecs are diferent try burning the cd with another software like alcohol.... maybe you should adjust the speed of recording.....
Posted on Aug 23, 2011
Brown mute wire for new ken wood in 2002 rodeo, does it go with illumination wire, green/red or red/green?
Hi, i'll need a bit more info to be able to give you an opinion , am i correct in assuming the "new kenwood " is a radio/cd player ? If so do you have a car phone or a hands free kit for your mobile/cell phone ? Assuming the kenwood is a radio the mute wire has to be connected to the car phone/mobile hands free kit , this is usually described in the phone installation directions , how the mute system works is when you recieve a call the signal is sent via the phone system to the radio , which is where the mute wire comes into use .If you have either of the phone set ups i've described post back with there details , make , model etc ,if you do not have this type of system and are using an ear piece then the mute funtion can't be used , i hope this is of some help to you
Apr 06, 2015 | 2002 Isuzu Rodeo
Cd player on mazda 626 plays cleaner but will not play cd's
Mazda's have a history of this and no one like's to work on them,just want to sell you one,I called a dealer to get mine repaired and other shops,no one work's on them anymore.So I bought a ken wood,had it 11 years,still like new,has clock on it and can remove face.
Nov 16, 2013 | 2000 Mazda 626
Radio CD code for a 50645P 2003 Hyundai Santa Fe.
Trent, with any factory systems you must grab the vehicle's VIN or have your registration and call Honda Service or Parts they will be able to provide you with the code. You will need the radio and CD changers serial numbers. Hope this helps buddy, let me know if it works for you. Lex.. 11_2_2013_3_10_53_pm.jpg
Oct 10, 2013 | Car Audio & Video
I bought a 06 ultra, and I can not get the CB to work, does it require a program? code? can it be done at home? everything else works great,
CB module is a auto-detect through the radios CAN BUS data system. There is no flash or programing required. If you press the "com" button on the radio, it should bring up the CB menu. If it does not display, check the wiring to the CB module and make sure it did not loose power.
For more info, contact Iron Cross Audio
www.ironcrossaudio.com
Apr 11, 2011 | Harley Davidson 426290 AM/FM Radio
No Audio
IT MAY BE A GOOD IDEA TO CHECK THE WIRES BEHIND THE HEAD UNIT AS THIS IS WHERE EVERYTHING IS POWERED FROM, MAYBE A LOOSE EARTH LEAD OR MAYBE A LOOSE POWER LEAD, SOMETHING SOUNDS LOOSE.
Jun 18, 2009 | JBL BP1200.1 Car Audio Amplifier
RADIO
over heated it man thse radios very poor heat protection off brands not great for sterios alll day no ventlation main amp no good i would just get new ken wood calrion ect ok
Oct 08, 2008 | Power Acoustik PTID-5800 Car Video Player
Homedics SS-4000 Clock Projection Display Problem
per Ken in response to SS-4500: Worked for me right away! keith Ten8
Rank:nonexpert_s.gif Apprentice
Rating: 92%, 6 votes
To fix the projection display that is stuck with four 8's, hold down the hour and miute button at the same time. Keep the buttons pressed down while unplugging the power source then pluging it back it. I did this and the screen works like it did when I first got it.
Ken
Jun 07, 2008 | Homedics SS-4000 Clock Radio
Dodge RB4 GPS system
Sounds like the J1850 bus is not connected to the RB4 radio.The speed sensor info is received thru the bus which alows the nav to function and calibrate itself.Or as I have mentioned before, there may be problems on the NAV pcb.There have been many issues with the nav pcb assy.
Jun 23, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Dodge RB4 nav system problem
See my other Posts which refer to this problem.
Gps is not working
I know the is a old post but i will provide some answers to the question.
1 the radio has to be connected to J1850 bus to talk with the sensors in the vehicle
2 check nav ant for broken wire.
3 check nav ant socket (center pin) should have no less than 4.95 volts DC with radio on.
4 Problem more than likely on nav PCB .
I have run across MANY problems on the nav pcb.
May 23, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Kenwood DNX5120 DVD Navigation System GPS Receiver Logo
161 people viewed this question
Top Kenwood GPS Experts
Marvin
Marvin
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
