I have a Lexmark X3550 printer There is a paper way down inside that cannot be reached Tried the automatic remove and it does nothing. What should I do?This machine is only a few months old.
Bending the bottom exit tray will allow it to be removed. Simply remove tray and wipe rollers right in front of the bar that the ink slides back and forth on. Most printers get a lttle dust on the rollers then they wont feed. Hope this Helps.Sincerely Brian @ Game-On Computers.
Posted on Mar 17, 2011
    Genius:
  • 1,447 Answers
If the paper is lodged too far into the printer and can't be removed:
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
If that doesnt help call this number
Posted on Apr 26, 2008
Removing paper jam from lexmark x3550
Use a strong light to examine the entire paper path. You may find one or more tiny bits stuck in a tiny space. This may be a result of feeding old or thin paper in previously
Jan 26, 2013 | Lexmark X3550 All-In-One Printer
I have a very deep paper jam. The paper can barely be seen when looking down into the paper feed. Paper cannot be seen from the front where paper comes out. The paper is apparently folded very tightly...
Hi Rosemary, thanks for contacting me to help you fix your printer problem.
Well, have you tried removing the Paper Trays? There should be two trays and both of them are removable. Once they are removed, you'll be able to see through inside the paper passage in order to remove the jammed papers.
Remove the lid from the top of your printer. This lid protects the scanning bay. With the lid in the fully "open" position, lift upwards on it to separate the lid from the base of the printer.Now, remove the printer paper trays. These trays will pull directly off of the body of the printer. There are two paper trays -- one on the top of the unit and one on the front of the unit, beneath the control panel. Once they are removed, you will be able to see inside the passage where the papers are usually jammed. If your fingers can't reach the jammed papers, use a pair of tweezers to remove them. If you still have problems, let me know.
Good Luck.
Thanks for using FixYa.
Regards,Nonontech.
Oct 03, 2011 | Lexmark X5495 Printer
A pen was dropped inside back of printer and it needs to be removed. The printer is not working properly; there is a rattling sound. Thank you
If you are willing and able, remove the printer from the power source. Disconnect the cables from the back of the printer. Remove any paper from the paper feed tray. Holding the printer in both hands, carefully turn it upside down to see if anything falls out of the paper feed area.
Mar 21, 2011 | Lexmark X3550 All-In-One Printer
My lexmark x5630 has been showing paper jam but there is nothing inside the printer thats stoping it please help.
Hello. Try removing all sheets of paper from the printer. Make sure to check in the feeder by peeking inside it. Clear any foreign objects. Open the printer cover, and remove the cartridges. Clear any foreign objects around the cartridge carrier. Close the printer cover without the cartridges. Unplug the printer from the power outlet. Plug the power back after 10-15 seconds. It should power on automatically. When printer asks for the cartridges, load them back in. Close the cover down. Printer will print an alignment page. Just let it finish print the page. When there's no more error, try to make a copy or print from the computer to check. Hope this helps.
Mar 09, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
I have not received the software disc to load my Lexmark X3550 on
No Problem, go to the below link and type in your model x3550 where it says search by model.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Download the drivers to your printer listed there... it is just as good as getting the software... probably better because it has been updated. Hope this Helps!
Sincerely,
cdixon18
The Man Inside the Machine
May 18, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
My lexmark x3550
can you tell me how to fix iy
Nov 10, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X3350 paper will not go through
you may have something inside on the bottom of the paper feed area what you should do is
1. unplug the printer
2. pull the paper out
3. GENTLY flip it upside down and give it a good shake
4. if you hear anything moving then put it down and take a flash light and look down and see if what ever was moving around is there.
5. if there is something there then take a pair of needle nose pliers or your hand and GENTLY remove after that plug it in and it should work
Aug 23, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Add Lexmark X3550ack on my cp -deleted by mistake
what I would do is delete the hard files first. do this by going to Start then hitting the Search button in the search bar type Lexmark X3550 and all subfolders do a search in your hard drive more possibly labled C:// drive once all those folders appear making sure that only Lexmark information is shown drag and drop these in the recycle bin. next go back to Start-then Control panel-then add or remove programs scroll down once populated search programs appear search to see if there is an icon for lexmark if this is so then click add or remove button after highlighting and click to remove. the next step is to remove the printer from the computer and remove the power cord. reinstall the printer as a new install first time install follow the instructions that are on your install disk.
Aug 04, 2008 | Lexmark X3550 All-In-One Printer
222 people viewed this question
k24674
jasbo
jasbo
