Cold water is very slow filling the washing machine. Hot water works great.
  • 869 Answers
Remove cold hose and clean screen out in the valve turn hose on and flush out .... put hose back on and re test. Please leave a rating !
Posted on Aug 04, 2010
SOURCE:
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
  • 209 Answers
SOURCE: kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Posted on Oct 14, 2007
  • 156 Answers
SOURCE: Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Posted on Feb 27, 2008
SOURCE: Slow cold water fill in washing machine
Take out the screen on the cold water side of the fill valve where the hoses attach, its probably clogged.
Posted on Mar 17, 2009
mgprice
  • 744 Answers
SOURCE: Cold water wash very slow fill up
Hi, you have a blockage on the cold side of your inlet valve, take the hose off on cold side of the valve and inspect screen..You may find some debris. If no debris is found you may have a bad valve..your going to need to replace it...if you have any questions please don't hesitate to contact
Posted on Jun 23, 2009
Water when filling has slowed down cold water is very slow hot is ok
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Very slow filling of cold water. Hoover 5 Kg
heatman101
May 23, 2011 | Hoover Washing Machines
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Mar 31, 2011 | Washing Machines
Hot water fill is very slow
heatman101
Feb 05, 2011 | Whirlpool Washing Machines
Only get cold water. No hot or warm water.
heatman101
Feb 05, 2011 | Washing Machines
Why does the hot water work but not cold water
heatman101
Jan 19, 2011 | Maytag Washing Machines
My Maytag LAT9400 top loading washer has stopped allowing hot water to enter the tub, only cold water works. What might be wrong?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 06, 2010 | Maytag Washing Machines
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
