Question about Refrigerators
How to remove the front panel of a Frigidaire side by side because the water dispenser just broke and i need to remove and by a new one
    Scholar:
  • 150 Answers
If you mean the trim around the dispenser you can pop it off with a putty knife
Posted on Apr 26, 2008
How do I repair/replace the ice dispensing paddle? Mine broke in half! I have a Frigidaire FRS26H5ASB4
The panel comes off some snap off others have a couple screws hidden under the drip tray. After removing the outer panel, you will see some screws holding the paddle in place.
Sep 24, 2014 | Frigidaire FRS26H5AS Side by Side...
Noticed that our frigidaire crown series front loader washer has been leaking while wash cycle is going. Leaks occur at two places: from the bottom side of the door and also from the detergent dispenser...
Well from what ive seen the detergent dispenser will usually leak due to an excess build-up of fabric softener. If you remove the drawer and look up at the top of the dispenser you will see numerous small holes. If you see moldy gunk its fabric softener residue. This usually restricts the water coming into the dispenser causing it to "shoot out" in random directions. To correct the problem you can take a putty knife and scrape off the visible build-up then take a piece of wire or a pipe cleaner and stick it into the individual holes and clear them out one by one.
If you feel confident you could go as far as removing the top panel and the will be one access screw from the front panel that you can see and the dispenser can be removed. Be sure to disconnect the hose that hooks into it (it can be hard to remove and put back on) but then you could actually rinse it out, which is what I usually do.
If your leaking from the bottom side of the door its usually the way the water drips down from the dispenser or just a few drops of water from opening the door. Its common to see a water residue streak at 6 o'clock right under the door.
Hope this helps _MJ_
Feb 07, 2010 | Frigidaire FTF530FS Front Load Washer
I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Jan 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Frigidaire FRS26R4A Side by Side...
Changing out actuator
If you are speaking of the water dispenser actuator the parts ar removed from front of the dispenser control panel. Visit my site and enter model FRS26TS7DB5 into the model search feature. once there look on left of screen and choose photo # 15 it shows a breakdown of the parts. We also offer free help and assistance. Click link below, Thanks Sea Breeze seabreezehvac@yahoo.com
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
http://www.rharriman.com/SupportFiles/FridgeActuatorReplacement.pdf
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Handle replacement for water dispenser
Melissa, you don't get it from the inside. Remove the drip tray by pulling it out. You should see two screws holding the dispenser cover on each side of the bottom. Remove these screws and push up on the dispenser cover, there's 3 hooks on the top. Unplug the harness from the dispenser board and get the cover out of the way. Now is the hard part. You have to get at the module itself that holds the paddle. These can be a fight. If you go to Sears.com, go to appliance then parts and post your model number you should get a breakdown of the dispenser that will guide you. Catriver..post back
Dec 09, 2006 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
280 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
