Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer shuts off after just a few minutes, but will restart after cooling down
  • Maytag Master
  • 2,699 Answers
If the motor stops running after it heats up most likely the overload is poping on the motor,when the motor cools down it will run again,you need to change out the motor
Posted on Aug 04, 2010
  • Sal De Aug 04, 2010
    try running the dryer with no heat,that way it's just the motor that's working,when it shuts down check with a meter to see if you're getting power to the motor,if you are then you know the motor is bad,if no power you could have a problem with the board,
3 Suggested Answers
  • 85 Answers
SOURCE: dryer starts then shuts off
it seem like your motor could be faulty (overheating) causing the thermal overload to open, stopping the motor after awhile it will cool down and the thermal will reset, if this the case the bearings or the windings could be faulty
Posted on Dec 16, 2008
  • 63 Answers
SOURCE: Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
Posted on Mar 13, 2009
My kenmore dryer runs 10 minutes and shuts off and when you try to restart it it just clicks
Could be overheating and has shut down to cool off. Check lint filter and vents for unclogged conditions
Sep 13, 2017 | Kenmore Dryers
My gas dryer runs for a few minutes. It than shuts off. When it cools down it restart..
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Whirlpool LGQ9858P Gas Dryer
The dryer runs for a few minutes then shuts off and restarts in a few more minutes8xcccxb2
Sounds like your motor is getting hot, shutting down to cool off and coming back on. This is a motor that will have to be replaced. On some models the only other thing is could be would be the thermal link that is usually located on the back of the dryer. This would definitely be the cheaper part to replace. If possible, jumper around this thermal link, if it still does the same thing you will more than likely have to replace the motor. Good luck I hope this helps.
Apr 19, 2011 | Maytag PYE2300AY Electric Dryer
GE Dryer model DDE5700GCLAD
Replace the operating thermostats. Eric
Jul 06, 2009 | Dryers
Dryer shuts off after minutes, until cools down
have you cleaned the filters on it. it might be the thermostat if you have. or checked the outlet pipe for excess fluff.
Mar 26, 2009 | Dryers
Dryer starts then shuts off
Dec 13, 2008 | Dryers
Dryer shuts off and won't restart until it cools off
more likely a bad motor ..excessive lint build up in dryer will reduce air flow through motor causing it to overheat problem is by the time the lint problem is found and corrected motor is already gone
Nov 20, 2008 | Crosley CDE6000 Electric Dryer
Kenmor dryer Series 80 110 668 14690
based from your story, you are tiggering a thermal overheat protection device. as the device heats up, it would trip off the dryer, and comes back on again after a few minutes but as the heat increases, the device is being triggered faster until the device would no longer trips back because the dyer is so hot that it would take about 10 mins to cool down. i think this is just a secondary problem, your primary problem could be lack of air passing through the heating element. please check the stroller blade for dirt of flint and debri, check also the outlet duct, it could be clogged with flint also. i hope i was able to solve your problem.
Feb 21, 2008 | Kenmore 63942 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
227 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
