Question about Whirlpool Refrigerators
I have a Whirlpool refrigerator, model ET1FHTXMQ04, Ser EU0712174. It has a filter located in the front, but it screws into the bottom of the unit. I need to know if this filter, filters the water coming into the water dispenser (in the fridge) AND the ice cube maker (in the freezer). Please let me know, as I'm in a rental home and this appliance didn't come with a manual. Thank you
  • Whirlpool Master
  • 1,606 Answers
Yes your model filters both .
Posted on Aug 04, 2010
How do I access the drain pump on a Whirlpool Duet washing machine model WFW94HEXW2?
Hi Marc,
Unfortunately, access to the pump & filter is harder on the HEXW2 model than the Duets with the removable lower panel.
First you have to remove the lid panel (screws in top rear), then pull slightly rearward and up/out.
Next you'll have to remove the control panel, then remove the front drum boot from the front panel lip. A large diameter thin wire spring holds it in place, located just under the rubber lip edge. Begin the spring removal from a wire tab located toward the lower portion of the lip.
Then remove the door latch screws (IIRC), and the screws at the bottom edge and top of the front panel. The entire front panel must be removed to access the drain filter.
Nov 03, 2014 | Whirlpool Washing Machines
Whirlpool side ed25pq
Water filters are located either in the toe kick at the very bottom of the unit, or inside the fridge, usually in the upper right corner. If equipped with one the filter number will be printed on the filter it's self. You provided a partial model number. Pleazer Appliance...
May 04, 2014 | Refrigerators
Unable to locate water filter cartridge
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GD2SHAXLQ00/1198/0165000/W0205059/00001?blt=06&prst=&shdMod=
it says the filter is down on the bottom just like in this diagram,the model number you sent isn't the full number,if you open the fridge door and look on the right hand wall up near the ceiling there should be a tag there with the full model number,if it's an older unit it could be down near the bottom fridge door hinge,send the number back and i can check it for you.
Jul 20, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
How to change water filter
The water filter on this model is located on the bottom of the unit at the kickplate. You turn the unit counter clockwise to remove the filter.
Mar 12, 2013 | Whirlpool ET1FHTXM Top Freezer...
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing FixYa.com if you have any further questions please post back to the thread.
Justin
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Does whirlpool side by side ice/water on door model3ed2chqxvq02 SER#ar02655568 HAVE FILTERS ON THEM if so where is it located ?
The filter is located in the bottom grille or in the upper right corner of the fresh food compartment. Make sure you know how to change them. Some slide to open others have a release button and some unscrew. Make sure you run a few classes of water out after change to remove all the air. Instruction on how can be found here. http://www.whirlpool.com/catalog/refrigerator_water_filters.jsp?refrigeratorStyle=refrigeratorstyle&WT.mc_id=WhirlpoolWFSEMGooBrandGen Just copy and past this location in your web browser.
Sep 18, 2010 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Replace water filter
HI. Frist, make sure that your unit is equipped with this feature. if you have varifyed that your unit is equipped with a filter fo this nature, the location will be on teh front, lower grille area. This is the most common location for a water filter. Simply kneel down, and look at the bottom section of your unit, on the front. There is a grill, with a circular cut-out. This will be where the filter is housed. You will need to turn the handle counter-clockwise to release.
Now, in newer units, the filter will be located inside the refrigerator compartment, just above the top shelf, in the right, or left corner. if both locations do not show a filter, check the backside of the unit for a 8 inch cylindrical device.
Nov 19, 2009 | Whirlpool Refrigerators
No ice
sound like u have ice blocking the icemaker from moving..thaw with hairdryer. are the cubes a bit small?
Jun 09, 2009 | Whirlpool GS6NBEXR Side by Side...
Water filter
If you look on the toekick on the lower left hand side you should see a circular tab that is about 2 inches in diameter. This is your filter cover if you turn it 90 degrees counter clockwise your filter will release(if there is one installed)
Aug 06, 2008 | Whirlpool ED2SHAXM Side by Side...
Looking for refrigerator use and care guide for mod.ed2vhextbo1 ser.hrt4930458 and info about changing filter and type of filter
i do not think that is a good model serial number. at least not the format that whirlpool has used in several years or in the u.s.a.
the model serial numbers should be on a tag easily located with out moving unit.
unless this is a vendared product with a Whirlpool name on it (usually a dorm frig or the like)
May 15, 2008 | Whirlpool Refrigerators
Refrigerators Logo
253 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
