SOURCE: whirlpool side by side water dispenser not working
I had the same problem and it appear the cable set between the freezer door and refrigerator body has some wires broken. The cable is in the bottom right hinge. You can try moving the cable with fingers at the same time you're pushing the water lever.
While this is not going to be a permanent fix, at least it confirm where the problem is.
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
SOURCE: WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Please see potential solutions at diychatroom.com. Do a search on "whirlpool fridge flickering". I had the same problem, and the solutions worked - can save you the price of a board.
SOURCE: HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
