Question about LG LFX25960ST Stainless Steel French Door Refrigerator
I just took delivery on an LG LMX25984 french door refrigerator. No water is dispensed. Followed the instructions to purge air from the system by depressing the water dispenser arm. I can hear the sound of the dispensor operating, buf after 5 minutes, still no water. I checked again, and yes, there is water in the supply line. I noticed a 12VAC solenoid at the bottom rear of the unit. Did not seem to be energized. Placed a meter on the solenoid connector - no voltage at all. So what conditions must be met for the water supply solenoid to be energized and open up to allow water to flow?
  • 2,272 Answers
Its called solenoid valve.If the solenoid valve not functioning then check the power /voltage.If there is no voltage then it has to be replaced.but as you said its new then its under warranty.Ask the company to get it replaced.many a times the solenoid gets stuck up.Wiggle the solenoid valve a bit and recheck.If its due to any kind of loose connection. At the back of the unit is the water solenoid. You would see two. One for the icemaker and one for the water dispenser.
If you press the water dispenser pad, there would be one solenoid that would activate. If there is one activating, then check the water tank in the fridge section, this tank could be frozen.
If there is no solenoid that is activating, then you can check the solenoid if it still has resistance reading. If it has no resistance reading, then that is the problem. Replace the solenoid valve.The solenoid is at the back of the unit and you should hear it activate when you press the pad.
Cost of new valve is near to $70.
You can get it from www.repairclinic.com Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 04, 2010
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
LG french door no cooling
Pull away from the wall and remove the panel near floor to expose the compressor. Feel the top of the compressor to see if cool, warm or too hot to keep your hand there. Tell me your findings. Is compressor clicking? Is the model number LMX25984 above your post correct?
Appliance 911 Sea Breeze
Aug 10, 2015 | LG LMX25984
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
Lg lmx25984 ice chute flap will not open automatically
On Mine, the solenoid connection fell off that allows the ice to dispense, Thank you so much!
Aug 04, 2012 | LG LMX25984ST 24.7 Cu.Ft. French 4-Door...
Replaced water filter when trying to get water it HONKS loudly and no water comes out
You might have air in your system. Hold the dispense lever down for several second about every 10 minutes until you have the air purged.
Jan 15, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Water dispenser just stopped working. We changed the filter but made no difference. You could hear the new filter fill with water but when you press the dispenser button on the door nothing happens. LG...
This is probably a service call issue. The lines could be bad. The dispenser could be bad. You will be playing :poke and hope" and buying parts you don't need. The system is complicated and needs to be diagnosed by an authorized tech.
Jan 24, 2010 | LG LRFD22850ST French Door 22.4 Cu. Ft....
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Water is slowly trickling out of water dispenser
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Aug 05, 2009 | LG LFX25960ST Stainless Steel French Door...
How do you changing the water fileter
  • in case you haven't figured it out by now. open rt side door and top right corner is the filter push the little plastic tab and the housing drops down , a quarter turn counter clockwise and the filter should pull out, reinsert the new filter screwing clockwise and close housing, remember to pull water from dispenser right away you will have let air into system so some sputtering will occur till its purged
Feb 18, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
