Question about Cycling
My son inherited a Giant MTX 225 bike (I think a 2004 model). How do you adjust the handlebars closer to the seat (my son has to lean forward to reach them and it puts his back in an uncomfortable position)?
    Brigadier General:
  • 8,546 Answers
Stem length is the only dimension that can be modified, assuming the bike is not TOO long. They don't adjust in that direction but a Bike Shop can work with you to select one with a shorter reach and/or a different rise if necessary.
If your son has any desire to ride faster than 15mph or so for prolonged periods he's going to have to get his torso down and out of the wind, so a leaning forward postion would serve that goal.
Posted on Aug 04, 2010
Can the handlebar be raised on a 2015 giant anthem 1
The seat should typically be at a point such that your knee has a slight bend at the bottom of the pedal stroke. The handlebars go wherever they are most comfortable for you. Reach (horizontal distance) is adjusted with a different stem. Height on your bike can only be increased by using a stem raiser. The following Google search will show you what is available, and the video results will show the procedure to install it.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Sep 12, 2016 | Giant Anthem 1
How do I adjust handle bars to bring them closer to me
Some handlebar stems can be simply rotated towards you (Allen wrench to loosen and tighten), while others need to be replaced with a shorter stem.
Before doing anything, however, I recommend you first get a good opinion from your local bike shop on whether your seat is in the right position (height, as well as fore/aft). Then, they can help determine if the handlebars need to be closer and if it's just a simple adjustment.
Note: If stem actually needs to replaced with a shorter version, be careful about spending a significant % of the bike's worth.
Oct 07, 2013 | Trek Navigator 300
Bike to high
If the big is really too big, then it's not safe to ride, and blocks on the pedals are not a good idea. On the other hand, if you can straddle the frame of the bike with your feet nearly flat on the ground, then the bike is not too big. You can lower the seat, and many seats can also be adjusted forward and back an inch or two. The optimum seat height is when you put one pedal all of the way down, with the heel of your foot on the pedal, then you should be able to lift your weight off of the seat. You can also bring the handlebars closer if the handlebar stem you have has a typical length offset (if you picture the handle bar stem as an inverted hockey stick, the the offset is the length of the hockey stick blade) - if so, you can replace it with a stem with a smaller offset. If the stem already has a very small offset, you can turn it backwards, but don't do this if the offset is more than 1 inch.
Good luck.
Jun 20, 2012 | Schwinn Cycling
I want to raise the handlebars and the seat for this bike, I purchased it second hand
http://www.giant-bicycles.com/en-US/page/135/
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
May 28, 2011 | Giant MTX 260 DS
Hi Can I fit disc brakes to my sones Giant MTX 225?
Not unless you see the tabs required to mount traditional standardized disc brakes on the fork and left seat stay.
Converting this bike to disc will cost you more than the bike is worth. Get a bike with disc on it.
http://www.youtube.com/watch?v=7Dus9jGmGLI
There are some schemes for adding disc to non-disc-compatible frames but they're Rube Goldberg solutions. And you still need to get new wheels and new brake levers if you're going with hydraulics.
http://answers.yahoo.com/question/index?qid=20081220203159AAUvKFx
Apr 22, 2011 | Giant MTX 225
FRONT HANDLE BAR OF BIKE IS LEANED STRAIGHT FORWARD, WHERE MY SON WILL FLY OVER THE BIKE. HOW CAN I STRAIGHTEN THE HANDLE BAR FRONT OF THE BIKE BACK UP?
Of course you can, but make sure that you do not strip the bolt holding the handlebar. Use metric tools, not SAE.
Aug 18, 2010 | Cycling
Can you adjust handlebars of yamaha 650 v star 2004 model. right side seems 1/2 inch closer to rider. Gives the illusion of going down road a little sideways. forks appear straight. i am buying this used...
Handlebars can be adjusted up and down, but I know of no way to adjust bars forward and back. I would check the levelness of the forks just to make sure that the motorcycle has not been in a front end collision.
Mar 13, 2010 | 2004 Yamaha V Star Custom
Cycling Logo
147 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
