How to fix a sansa fuze mp4 player when it won't turn on
  • kakima Aug 04, 2010
    Slide the power switch all the way up and hold it there for at least fifteen seconds. Does that do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Audio Player... Master
  • 102,366 Answers
Having gone over a month without a response, I assume the reset solved the problem.
Posted on Sep 19, 2010
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa mp4 player startup hang
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
SOURCE: my sansa fuze 4 gb will not charge or now won't turn on.
what is a bit muda?>?>
Posted on Oct 15, 2009
Schmead10
  • 650 Answers
SOURCE: can't download video's to my sansa fuze
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu go to sansa choose converter(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link
Run this program or save then run
Posted on Nov 02, 2009
digritz
  • 530 Answers
SOURCE: when i turn on my sansa fuze 8GB player it always
You got three choices. Fix it, Ship it or Forget it.
You need to check out your warranty. You also need to forget it if you damaged it somehow and it shows.
The most common cause is the battery no longer holding a charge. There are a lot of sites that you can send your media player in to and they will (for a small fee) install a new battery To be honest though the battery should last a little longer then the energizer bunny.
If you are out of luck because it's out of warranty, you got nothing to loose. The fix it depends on your genes. If you have what I like to refer to as the "I Don't Care If It's Not Broke I want To Take It Apart Anyway" gene then have at it.
If you don't find a friend who does. Really you will make his day. If your not sure all I can say is if it went together it will come apart. I have 12 to 15 cell phone and 4 or 5 different models of ipods that will attest to that. I know it seems like a lot but I have 4 times that repaired so my average is pretty good.
It may just be a simple matter of re-seating the interior components. It kind of depends on what caused this to happen.
You can also give the link below a try for more info regarding a replacement battery.
I really hope this helps.
http://forums.sandisk.com/sansa/
Posted on Dec 26, 2009
  • 102366 Answers
SOURCE: I can't see videos in my Sansa Fuze mp3 player
You need to use the Sansa Media Converter to convert videos (and photos) to a format the Sansa can handle.
Posted on Apr 23, 2010
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
Cant play video
Not all Video format are supported by the Sansa Fuze: make sure you use 'Sansa Media Converter' to convert your video to a suitable format which could include (from Sandisk manual):
3gp/3gpp2, ASF, AVI, DAT, DivX(ver 6.0), DVR-MS, MOV, MP4, MPEG 1,
QT, WMV
Hope it helps!
May 03, 2011 | SanDisk Sansa Fuze MP3 Player
Cant play videos
It seems that your MP3 player can support mpeg4 video, but you should control your video resolution to 320*240, maybe you can to use Leawo free mp4 converter.
You can free download it here: http://www.leawo.com/video-converter/free-mp4converter.html
Mar 29, 2011 | SanDisk Sansa Fuze MP3 Player
My Sansa Media Converter won`t download videos or photos into my Sansa Fuze 4GB.First when I installed the Sansa Media Converter it wouldn`t recognize my Sansa Fuze.After a lot of research on the Internet...
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
tutorial;
http://www.downloadvideos-convert.com/how-to-use
Jun 16, 2010 | SanDisk Sansa e260 MP3 Player
How to put videos in sansa mp3
Hi There !!!
If you want to add videos into MP3 player. I would say you have to have the Sansa Media Converter (SMC) to be installed in the computer.
For your kind information, the file format supported are : ASF, AVI, DAT, DivX(ver 6.0), DVR-MS, MOV, MP4, MPEG 1, QT, WMV, and 3gp/3gpp2
Feb 02, 2010 | SanDisk Sansa Fuze MP3 Player
How do i put videos on my sansa fuze
Sansa Video Converter can transform all common formats to MP4 video andMP3, OGG, WMA audio for Sansa. More importantly, Video Converter forSansa is easy to use by few clicks for both Sandisk new users andseasoned Sansa owners.
Dec 07, 2009 | SanDisk Sansa Fuze MP3 Player
Can't download video's to my sansa fuze
Nov 01, 2009 | SanDisk Sansa Fuze MP3 Player
How to put videos to sansas fuze?
maybe u can try this one to slove your video problems.
or more help from
http://kb.sandisk.com/app/answers/list/
May 27, 2009 | SanDisk Sansa Fuze MP3 Player
53 people viewed this question
 Grubhead
Grubhead
