Question about Whirlpool GHW9400 Front Load Washer
I have a whirlpool duet front loading washing machine model #GHW9400PLO. I have been noticing musty odor from my machine. After inspecting the washer, i noticed an article of clothing (small sock) has become trapped under the drum by the heating coil. Is there any way to retrieve it?
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!@
Posted on Sep 28, 2010
Do you need to keep the door open when not being used. i know some models require that.
There's no special requirement that you need to keep the door open. But, If you keep it closed after your done washing, some water is usually left behind and if you don't wash for a few days it could make the first few loads have a certain musty odor. I always leave the door open for a few days to dry out the insides then close the door and I haven't noticed the musty smell. Good luck.
Apr 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a musty odor after my clothes are washed. What's the problem. I clean my machine monthly with bleach.
I use 20 mule team borax and leave the door open when not in use and have no more musty smell in washer or clothes.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Any significant issues with 2004 Whirlpool Duet washer/dryer?
No more than ordinary.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Musty odor
The following link can provide you with some good info on how to control and prevent mildew and odors in a front loader:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Several factors that DO matter when it comes to the proper care of a front loading washing machine:
1. Leaving the door open when not in use.
2. Checking the bellow after every wash for lost articles of clothing.
3. Checking the drain pump reservoir periodically for build up of debris.
4. Use of the proper detergent (HE only).
I personally own one of these washers and have never had a mold or mildew problem in the 9 years I've owned it by following this regiment.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My model# is GHW9400PLO. And it flashes F 11.
communication error problem.
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent.
Inspect wire connections to the MCU, the motor, and Central Control Unit (CCU)
Inspect the Drive system for any worn or defected parts
Inspect the MCU, CCU, wiring harnesses, and motor
Replace the failed component.
check you manual some of these have 5 yr electronic part warranties
Jan 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer has a strong odor when draining
you might be getting "sewer gases" from your drain, but most likely your washer is the cause of the odors.
does it also smell musty when you get your clothes out?
whirlpool makes a product called "affresh" that is specially designed to clean out the residues from a front load washer.
you can find them at sears or lowes and the come in a package of 3 tablets. run a tablet on the clean cycle or on whitest whites or the longest cycle you can choose, use hot water and a second rinse option.
also to prevent this odor in the future make sure you are using only HE type soap and dont use too much. the least amount should do well to clean any clothes.
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9400PLO
The "Fdl" code is a Door Latch Lock error. Inspect the door latch for obstructions that may be preventing it from locking and doublecheck the wire harness to ensure all the connectors are intact. If the latch is defective, use the following link for advice on how to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Another method of replacing the latch is to remove the top panel and work form the top down behind the front panel. Due to limited space, this may not be desireable to some.
Replacement latches can be purchased on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for your search criteria. These sites have great service and offer competitive pricing. Check out all three for the best savings.
I hope this information helps you. Let me know if you need further assistance.
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
136 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
