Question about Shure Beta 87A Professional Microphone
Weaker sound,not a fake. - Shure Beta 87A Professional Microphone
    Novelist:
  • 169 Answers
Check the wiring at the xlr first, maybe 1 leg of the balanced output has come off or maybe a bad solder joint inside.
If its weak and thin then it sound like this might help.
Hope this helps
Thanks for using FixYa
Posted on Aug 09, 2010
  • Rick Jan 24, 2011
    It can't be a problem with the XLR connector. If a wire came off the XLR connector, the mic would not work at all. I suggest contacting Shure to have the microphone repaired. www.shure.com/service
Need Fake City Names!!?
Do your own work, or your'e grounded!!!!
Jan 04, 2017 | Books
Tip
Car won't start? try this!
Is your car clicking when you try to start it?
does it make u think your battery is low, but it isnt?
There are two reasons for this.
Reason #1 (most common)
Y
our starter solenoid will click but nothing else when u try to start your car if your starter is not getting enough power from the battery. This can be caused by a low battery, however it can fake you out and seem like that battery was getting weaker and weaker over time even tho what was actually happening was that the grounding cable (black thick wire) going from the battery to the starter or a bolt on something metal under your hood may actually be degrading over time and need replacement.
Fix: #1
test your ground cable with starter cables! put the negative(black) on the battery then the other black end on anything metal that doesnt move and is not painted. also make sure its not in a spot that could loosen and fall into moving parts if the engines starts. Try starting your engine. If it starts you now know that your ground cable is bad. They are about $5 at autozone and 2 bolts to replace. Just follow it from the battery down to where its bolted on.
Reason #2
Y
our starter solenoid could be bad. If you hear a clicking and you tried the above to no avail. You may need a new solenoid. Its the small cylinder looking thing attached to your starter. To replace the solenoid you will have to remove your starter. Some makes and models don't allow you to purchase the solenoid separately.
on Dec 30, 2009 | Chevrolet Cavalier Cars & Trucks
Land rover alarm and car horn
your remote is picking up another signal some place and your cars being haunted by it
reset alarm settings
now the other problem is your battery is getting weak loosing its charge because its constantly on simple get charger to trickel charge system or replace battery
Nov 09, 2013 | 2008 Land Rover Range Rover
Horn on my 2003 monte carlo stopped working. The volume got weaker and weaker until finally no sound is made when you press the horn
do you hear a click sound from a relay when pressing on horn button? most likely is underhood. if so,locate the horn(s) and test voltage with a test light or DVOM at the horn + side. if both have voltage,check - side.(ground).if both are correct replace both horns.
Sep 27, 2011 | 2003 Chevrolet Monte Carlo
N73 low sound for top loud speaker and earpiece when calling
HI, when a cell phone has Low sound for top loud speaker and earpiece when calling , it is when the loud speaker and the earpiece are weak to perform accurately and will need to be replace for better sound quality for your cell phone.
When a phone drops on the flow or water gets into it,might cause the hearing of the lod speaker sound to go weaker and weaker every time.
When you replace the ear piece and the speaker, you phone will work perfectly again.
If when you replace the speaker and soundisstillthe same , that means it's an IC chip problem inside the cell phone . An expert will help you on that.
Hope it helped.
Thanks for using fixya.
Feb 10, 2011 | Cell Phones
Wont start
is your battery good? headlights nice and brite?
are there any blown fuses? (fuses usually found under dash below steering wheel)
do you hear a clicking noise? does it seem like your battery is low even though you know it is not?
Y
Fix: #1
Dec 30, 2009 | 1997 Chrysler Town & Country
Theproblemisinitssound thier is no soundbut also bad picture
try the AV input, using dvd player
if it there's no problem, the sinyal receiver is weaker...
but, if it so, perhaps the frequency of your television is weaker...
this problem have to solved by technician, it contain electric shock,
find one in your area
Aug 22, 2009 | Televison & Video
My nintendo ds shuts off before soon as i turn it on.WHAT TO DO!!
that may sound like a batterie problem, try buying a new batt and see if that helps, depending on how long you have had your ds the batt gets weaker and weaker over time and all you can do then is get a new batt. hope that will solve your problem.
Apr 09, 2009 | Nintendo DS Lite Console
When I turn the key it just clicks
The battery may have just been replaced, but have you checked the voltage lately?
This sounds like it may have a charging problem.
First, put the battery on a slow charger over night, and see if it will start the next morning.
If it sounds strong, but get weaker after running for a while, you'll want to check the output of the alternator.
You can take your Venture to a local autoparts store, and ask them to run a charging check for you.
Aug 27, 2008 | 2000 Chevrolet Venture
Shure Beta 87A Professional Microphone Logo
133 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
