Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
Little Green pro heat is leaking from bottom with very little suction. I just purchased it.
  • 276 Answers
Try the following suggestions for the leaking issue:
- Check to see if the black or white "duck bill" gasket is misassembled or missing from the collection tank; ensure the gasket will open where the flat flaps meet and then reinstall it. The duck bill should be inserted into the curved side of the collection tank.
- Check to see if the solution tank/cap insert is leaking.
Note: When the solution tank is filled and turned right side up, the straw on the insert may fill with water/solution causing the tank to leak for a couple of seconds. This leaking should subside after the straw empties out.
- Check for proper placement of the o-ring on the cap insert. The o-ring should be between the bottle and the insert piece (part with the "straw").
Try the following for the suction issue.
- Remove the Collection tank and locate the circular motor duct on the base of the machine. Turn the machine on and feel for suction at this location. If you feel suction proceed as follows:
- Remove the gasket from the bottom of the Collection Tank. Ensure that this gasket is open (not sealed shut) at the top of the gasket where the flaps meet. If the end is not open, simply squeeze the end to open it. The “duck bill” shaped portion of this gasket should align with the rounded side of the Collection Tank.
- Check to make sure there are no cracks in the flexible vacuum hose or in the tool you are using.
- Make sure the collection tank latch is locked down securely.
- Check for suction at the end of the hose with the attachment off by suctioning water out of the sink or a cup. If there is low/poor suction, check the hose for clogs by raising the hose handle above the unit to allow the water to go into the collection tank.
The issues may be related as you can see some of the suggestions are similar.
Posted on Aug 05, 2010
Bissell little green instruction manual
Hi, it's Jeremy from Crucial Vacuum.
Attached is a copy of the user's manual for your Bissell 1400 Little Green Pro Canister Steam Vacuum:
http://www.bissell.com/assets/0/132/134/228/83bcc4e8-41c1-4b5f-8547-17c9af450a80.pdf
You can purchase direct your Bissell replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 04, 2014 | Bissell 1400 Little Green Pro Canister...
I have changed the hepa filter & made sure the washable filter is clean. I checked the brush & it's working fine. The indicator is still red very little green. Not suctioning good at all. What...
check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself and you will need to take the unit into the repair shop and have the motor rebuilt or replaced.
c..
Feb 02, 2011 | Bissell 3920 Bagless Upright Vacuum
Lost instructions for Bissell little green pro-heat how does it work
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 03, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Directions on how to use the little green pro heat Bissell
I believe you will be able to download your manual at this URL site:
http://safemanuals.com/zearchres_3935.php
Paul
Sep 18, 2010 | Bissell 1425 Little Green ProHeat Handheld...
I have a Kenmore Progressive Inteleclean Upright vacuum cleaner (with Bag) . It has good suction only through the hose now and none through the bottom for cleaning carpets. and, there is a noise like it...
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Sep 22, 2009 | Kenmore Progressive Bagless Upright with...
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Leaks out the bottom
ther is supposed to be a black rubber gasket with a cone/triangle looking thing that may not be in place
Jul 01, 2009 | Bissell 1400 Little Green Pro Canister...
Clean solution leaking out the bottom
open it up again and check the pump there is probably a hose leaking ,did you put the clamps back on the hoses
Apr 14, 2009 | Bissell 1400 Little Green Pro Canister...
Air leak
Check the seal that is in place between the top and bottom sections. If it came out of place even a little, it will leak and you lose suction. Part number 03611180, it is called a buffer.
Dec 22, 2007 | Miele S251 Flamenco II Bagged Canister...
Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
3,786 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
