Need wiring diagram for installation of an A.O. Smith DL1036 blower motor. Unsure is it is wired correctly. Wires provided are Black, Red, Yellow, and Blue.
  • 407 Answers
These wire colors are the different speeds for the motor. You will have 1 wire going to the heat, 1 wire going to the cool, and 2 wires on the park terminals on the board if available. It will actually tell you the speeds of the colors provided on the motor itself i.e. BLACK=High and so on. Without knowing what model of unit you are working on, it's hard to say where exactly the wires will hook up, but the majority of the time you will have a electrical board inside the furnace and the terminals that I described will be marked. Hope this helps and good luck!
Posted on Aug 05, 2010
Iam replacng my home a/c blower motor. My unit hasa red a black and a white wire. My new motor has a black wire a blue wire a red wire and a yellow wire. I need to know which color wire goes to which
On the original motor, red was low speed, black was high speed and white was common. The new motor should either have a diagram on the side of it or within the box for verification, but the black SHOULD also be high speed and the red wire SHOULD be low speed , the blue wire SHOULD be medium and the yellow SHOULD be common. However, you MUST verify those connections on the wiring diagram provided with the new motor before you connect or you will probably let out the MAJIC SMOKE !!! The speed you decide not to utilize can just be taped off and zip tied to the bundle.
You made no comment about two brown wires, and if either motor has two browns, they go to the run capacitor.
Dec 23, 2014 | GE Heating & Cooling
Replacing home a/c blower motor the unit has black and white wires my new motoe has blue lack red and yellow wres How do i wi it?
DO YOU HAVE A WIRING DIAGRAM OF THE NEW MOTOR? TYPICALLY NEW MOTOR WILL HAVE OPTION FOR MULTIPLE SPEED MOTORS.
WIRES ON UNIT NEW MOTOR
WHITE.............................NEUTRAL.........WHITE
BLACK ...........................HOT...................RED=LOW
OPTION 2 YELLOW=MED/LOW
OPTION 3 BLUE=MED/HI
OPTION 4 BLACK=HI
Dec 09, 2014 | Heating & Cooling
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Mars blower motor diagram?4 wires
Gentlemen,
I have a GE P547BS fan motor. I find replace it with a Mars 10584 fan motor. GE has five wires, BRN, YEL,PUR,BLK,RED. Goes through the capacitor with the yellow going on to 200 V the purple and black go to 220 V. Mars motor as a six wire connection two Brown's go to the capacitor. yellow I'm assuming goes to the hot/neutral and a black I would say would be high-speed blue is medium and red is low. Now when I connect with this way it blows the fuse. Anybody run into this problem before? Any help? By the way, it's a 240 V single phase system.
Jun 05, 2012 | Heating & Cooling
Breaker keeps tripping when turning on pump.
The red and black wires if ran correctly are the load lines(power). The white is neutral or ground. If its a 1/2 to1-1/2 hp motor connect the red and black wires to terminals #1 and #4. If its 2 hp use #1 and #4. If its 3 hp use #2 and #4. Connect the white wire to the green colored screw. A grounding conductor should always be connected under the green grounding screw, which is located within the terminal compartment of the motor. You can check the breaker for the wire colors, one should be black and the other red. The white wire should be terminated to the neutral/ground bar in the can.
May 16, 2010 | AO Smith 1 HP 115/230V 56C Replacement...
Which wires goes to which post ? Just bought an ao smith 3/4 hp booster motor for my polaris pool cleaner. It has two yellow wire posts. Which do I conect the black and white wires to?
It does not matter. Just make sure it is set to the correct voltage your system supplies to it and that you put pne wire on each terminal as the diagram on the side of the motor will show you.
Jun 11, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Need connection diagram, AO Smith motor FDL 1056
Black is high , Blue is med. , red is low
Feb 19, 2009 | Heating & Cooling
Heating & Cooling Logo
866 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
