Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
Blinking lights on control panel
The normal wash and heated dry buttons lights blink continually. The dishwasher makes a beeping noise every minute or so. I tried to push the reset/start button for 10 seconds to see if it will reset itself and it will not. How can I fix this?
  • 4 more comments
  • richwanket May 05, 2008
    I have the same problem starting on about the 1st of May. Will not reset. I have tried unplugging it--nothing except blinking lights and a beep every minute or so. this is a dishwasher that has only been used about 20 times tops....but was originally purchased two years ago to sit in an empty condo. HELP
  • Chris B 850 May 12, 2008
    I'm having the same problem, and my dishwasher is 2days out of warranty an GE want help at all, They will charge me 79.00 dollars and have some one come check it
  • Lsmith94538 Oct 28, 2008
    The normal wash and heated dry buttons lights blink continually. The dishwasher makes a beeping noise every minute or so. I tried to push the reset/start button for 10 seconds to see if it will reset itself and it will not. I have unplugged (rebooted) it but that will not fix it iether. How can I fix this?
  • Anonymous Dec 12, 2008
    Same problem here.
  • swatkins98 Dec 19, 2008
    our GE Profile dishwasher just started blinking after I tried to run a normal load. the normal light blinks & the start/reset blinks & I get a beeping noise if I try to restart. I noticed the cup for detergent doesn't shut now either.
  • Anonymous Mar 15, 2014
    Dishwasher is not working. Air Dry button is blinking continuously
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
Posted on Aug 04, 2008
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
Normal wash light is blinking but, won't start
Hello friend, thank you for your post!
From the information you have provided regarding the heated dry and washing lights blinking on your Electrolux dishwasher it sounds like it could be a possible problem within your control board. I would recommend resetting your appliance which you can by flipping the household circuit breaker in the off position for roughly ten minutes. If you continue to receive the blinking lights I would reach out to a professional to come and diagnose your appliance. I hope this helps. -Matt
Aug 12, 2014 | Electrolux Dishwashers
Refresh control panel
Instructions
    • 1
    • 2
    • 3
      Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
    • 4
      Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
      Hope this will be of help to you
      Have an awesome day
Feb 08, 2012 | Kenmore Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Green clean dishes light blinking instead not blinking. Dishes clean, but not totally dry. I removed them from dishwasher. Clean green light continues to blink after door is shut. Pushing cancel...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 04, 2011 | Kenmore Dishwashers
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Good luck.
Jul 14, 2010 | Microwave Ovens
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
969 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
