Question about RCA Universal Remote Control
Need Owner's Manual RCA Model RP 7977A Boombox AM/FM Stereo Radio/Cassette Recorder Compact Disc
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: RCA audio system,and three disc.
I always encountered that kind of problem,the audio works but discs player not working.This kind of a problem of a disc player had three causes,first the lense is busted already secondly the MPEG MEMORY IC is busted,thirdly the roller that's moving back and port bringing the lense set stock up full of dirt this is most common problem.That why whateveryou did is not functioning.If you know how to open your unit it's better. First you do is to clean the roller with the use of a lighter fluid to take the old greases that already harden with dirt. After that all is clean put a first class greases type-A only little to the roller and wipe the lense with a cotton buds. If all this procedure nothings happens,you better change the lense with desame code number, to avoid conflict.If the lense is change still not functioning that's the time you change the MPEG memory IC.I assure it to you it's works 100%.
Posted on Jun 15, 2008
smarthome2
  • 1114 Answers
SOURCE: I need a power cord for RP-7986
Depending on where you live, you can find them at Radio Shack, Walmart, most discount electronics parts stores,etc.They are universal except for the physical plug style at the unit side. Best bet is to take the unit with you if possible for a perfect match. Hope this helps
Posted on Dec 23, 2009
  • 910 Answers
SOURCE: Need instructions for turning off
Free PDF Instructions at the link below.
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/RC40_DOC_OM.pdf
Please leave feedback.
Cheers
Andy
Posted on May 10, 2011
Testimonial: "Thanks for your help. I have managed to misplace my user manual, and it has been very unpleasant to have the alarm activate every 10 minutes."
This is an RCA portable radio & cassette player. It is not in a car.
tune what you want then press memory set and the number where you want it .
Apr 16, 2016 | RCA AM/FM Stereo Cassette Recorder...
I have an older Memorex Radio CD Player compact music system (wall mount) that I need to take off the wall or find a manual.
MEMOREX Portable CD Player Boombox FOR PARTS OR ...
www.ebay.com/.../MEMOREX...CD-Player...PARTS...-/151141511...
eBayMemorex Portable CD Player MP8806 CD/Radio Boombox Fast Shipping ... Sharp Boombox CD Cassette Recorder Player AM FM Radio Portable Parts or ...
Oct 15, 2015 | Cars & Trucks
Rewind button on Coby broken - how to replace
nesecito el picki-up laser lens para un boombox coby modelo mpcd 450blk hern7869@gmail.com
May 22, 2012 | COBY-PERSONAL & PORTABLE Coby Mpcd450...
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
I lost my cord for my boom box model number RCD150. Where can I purchase another?
You can order for it online at ebay.com or just walk into electronic workshop within your area to get it.
Apr 06, 2011 | RCA AM/FM Stereo Cassette Recorder...
I need a power cord for RP-7986 AM/FM Stero Radio/Cassette Recorder/Compact Disc Player.
Dec 22, 2009 | RCA RP7986 CD Player
Want to know how to program a rca rcr3273n remote control thats got no code search button
If you have a later set and an older remote, it will not have a compatible code.
If you are just missing the codes for your remote, try here:
Some RCA remote codes
Sep 07, 2009 | RCA Universal Remote Control
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
Televison & Video Logo
230 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
