Question about Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag Neptune MDG5500AW that is not drying. It sometimes has heat but most of the time it does not. Can you help me diagnose the problem?
  • Maytag Master
  • 2,699 Answers
If it has heat the first 15 to 30 minutes and then no heat you have bad gas coils,they are located on the top of the gas valve,just remove the two phillips screws,remove the cover and change out the coils,
Posted on Aug 04, 2010
  • Sal De Aug 04, 2010
    the part number for the coils is 279834
  • Sal De Aug 22, 2010
    unplug the dryer and take out the two phillips screws that hold the door on and remove the door,now take out the other two screws opposite the door screws.now grab the right and left side of the front panel and pull forwards and remove the front panel. this is how you can get at the gas coils,also if the coils aren't the problem you might need to clean out the dryer.vacuum out the cabinet and if you have a shop vac blow off the motor and all the gas parts to clean it.you can blow the lint from the back forwards so you don't have to pull the drum and the front bulkhead.pull out the filter and vac that out,if it's clogged you'll have to remove the bulkhead to clean the duct that the lint filter slides into,also if the vent line is long,remove it from the back of the dryer and with a leaf blower blow out the line and all the lint will blow outside.you should do this once a year with a gas dryer so you don't have a fire and your dryer will run like it should.now with the front off plug the dryer in and hold in the door switch and start the dryer,watch to see if the ignitor glows and then the flame will lite,if it lites and it should because you said you do have some heat change out the gas coils like i said before and your problem should be solved,either the air wasn't moving because of a lint block or the coils are bad,they will work until they heat up and then they will fail.it says over 100 people looked at this but nobody said if they fixed the problem or not,i hope this helps somebody,good luck
Maytag Neptune MDG5500AW gas dryer takes long time to dry
Check the dryer vent ducts for clogs, internal and external.
Oct 23, 2011 | Maytag Neptune MDG5500AW Gas Dryer
The gas dryer heats then does not heat. The sensor says 99 minutes to dry close. Tried it on timed heat and it dries then stops drying. Sometimes shutting off completely!
Hello,Cheack to make sure your venting is clean and clear..If its blocked the safty thermostat will shut the heat down to prevent overheating.. If the vent is clean i would check the coils.When they start to fail it will heat then not cycle back on..
Jun 18, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag dryer Model MDG5500AW is running but the inside is cool and does not heat up. I tried both Sensor Dry and Time Dry, it still cannot het up. What could go wrong? And what do you suggest that i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Hi, Gas dryer does not heat up. It was on Sensor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag won't dry on any cycle
if you have gone that far you have it fixed
since you diagnosed that there was flame you can fix this really easily
unplug the unit
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083&diagram_id=678789#d678789
look for the two parts 7 and 8
those are going bad and will need to be replaced
hope this helps
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune gas dryer sense dry time at 99, little or no heat
If this is a gas dryer, I'd suggest an inspection by the gas company or qualified technician. If the jets aren't firing correctly, you are wasting gas and possibly creating a hazard.
Mar 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
464 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
