Question about Paintball Smart Parts Nxt Shocker
Not shooting properly. making a pft" noise when shot but no paintball comes out
It's a faulty o-ring in the bolt assembly, just unscrew the back to pull out the entire bolt assembly, and find the o-ring that is either old and stiff, or the one that is severed or destroyed. Be sure to apply lube after. And also be sure to clean the gun after every 6 hours of use or so by cleaning all the grease and dirt off the bolt assembly, with either a cotton towel or a microfiber, and only using water if you need to use something to help, don't use chemicals, it's eats away at the o-rings. The gun should work after all this
Don't forget to change your batteries as well.
And I realize this was a post from 2 years ago, but I'm answering it correctly in the case someone is having this problem and googles it to find a solution, because shockers are still great guns.
Posted on Mar 21, 2012
    Problem Solver:
  • 11 Answers
Its cause it not and ego
Posted on Sep 10, 2010
My paintball wont stop shooting but it has nothing to do with the co2 tank help?
The sear is not catching the bolt and resetting it properly. Or, there is not enough air pressure to push the bolt back to its original position. I would take it to a gunsmith. Parts fly out of a Tippmann if you open it up.
Jun 16, 2014 | Tippmann 98 Custom Act Paintball Gun
Spyder sonix pro paint ball gun shoots but when i shoot fast the paintballs break why and how do i fix it
You can read the reviews here, it may help you figure out the issue:
http://www.pbreview.com/products/reviews/4233/
Feb 08, 2013 | Kingman Spyder Spyder Sonix Pro Vertical...
I am a paintballing novice, should I try to play with players that are more experienced than me?
There are no set rules about this, however you should be aware that experienced paintballs will not be sensitive to your inexperience and may exploit this, you are better to stick to your own level of experience.
Jan 17, 2013 | Sport & Outdoor - Others
The paintballs just fall straigt out of the gun or shots like 5 at a time
The part that is bad Tippmann calls a "ball latch". It's a small orange rubber part that keeps the ball in place before the marker is fired. The parts is inexpensive it is common in most paintball stores or can be found online at www.tippmannparts.com
I highly recommend taking this paintball marker to a local pro shop to have the part replaced. You can service this marker at home but is not easy to put together if you have experience working on then, they have a few springs under tention that make it tough to put back together. If you are interested in doing the repair yourself I highly recommend doing it on on a clean floor in a clean room so when you disassemble it it will be easier to find the springs that could shoot out.
One thing that will make it easier is to leave the feedneck on. It will keep one less spring from jumping out at you, just a tip from a pro. I also highly recommend not using a spray lubricant and to only use oils in you tippmann made for paintball guns.
Sep 19, 2011 | Tippmann 98 Custom Act Paintball Gun
Screen comes on to start new game continue game when we shoot gun screen flickers like ive shot but cant go any where
The Hasbro Tiger TV paintball game will not work on HD (high def.) tv. I was having the same problem and decided to try it on an older tv and it worked properly. My grandson loves it. Hope this works for you!
May 30, 2011 | Hasbro Mission Paintball Trainer Tv Game...
My gun wont shoot. Ill **** it once and it will fire a dead shot then not recock
Time to lube (oil) the gun. A few drops of oil in the inlet hole (where you screw on your tank) should do and then dry fire the gun. If no luck you may need to tear down the gun and clean and lube the internals.
Here is your manual.
http://www.paintballadvisor.com/manuals/Tippmann%2098c%20manual.pdf
Oct 06, 2010 | Tippmann 98 Custom Act Paintball Gun
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
Play hard, play safe, play with honor!
8^)
Aug 19, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
My alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Jun 11, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Paintball Smart Parts Nxt Shocker Logo
Top Paintball Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Paintball Sport and Outdoor - Other Expert? Answer questions, earn points and help others
