Question about Texas Instruments TI-83 Plus Calculator
When i put an equation in Y= the parabola appears but not the graph. why? it was just fine
  • Texas Instru... Master
  • 8,016 Answers
The truth of the matter is that the curve drawn (the parabola) is the graph that you are seeking.
It is possible that you you mean by graph is the the set of axes. In that case you may have deactivated them. To reactivate them:
  1. Press [2nd][ZOOM] to access the (FORMAT).
  2. Press the DownArrow key 3 times to reach the line AxesON AxesOFF.
  3. Use the rightArrow to highlight AxesON and press [ENTER].
  4. Your graph will have the axes displayed.
Posted on Aug 04, 2010
Minimum or maximum values of a parabola
Follow these steps: graph the parabola and after that 2nd then CALC keypad. To find extreme value of the function select 3: min or 4: max options. Select the function and set left bound, right bound(using left and right arrows) by pressing ENTER. You can see images bellow for all these steps for the y=-2x^2+5x+3
1. step: graphing parabola
2. step: left or lower bound
3. step: right or upper bound
4.step: extreme value of the function
Mar 08, 2012 | Texas Instruments TI84PLUS Slvr Viewscreen...
My fx-9750GA PLUS wont graph lines, cicles or paraballas
Sure it does! Did you ask it to graph?Here are some screen captures to help you find your way.
To draw functions (regular, parametric, polar, sequences) use the application graph: Highloghted on 1st screen capture. The second screen captures shows you the functions y=f(x). enter a legal expression and press F6 Draw. To set TYPE press the key under TYPE.
To draw conics (circles, parabolas, hyperbolas, and ellipses) use the CONiCS applications. (See 3rd screen ). On 4th capture the equation highlight is one for the parabola. y=x^2
Scroll down or up examining the small graphs. They will show you which equation form to choose.
For the circles
Jun 19, 2011 | Casio FX-9750GPlus Calculator
How to set up mode for graphing
To draw a graph, it helps if you know approximately where it is going to show up so that you can set up a window.
Try this:
Press the [Y=] button
Enter the following equation: 5*x^2-5*x (five x-squared minus five times x) by pressing the following calculator keys:
5 X (times) x^2 (x squared key) - (minus) 5 X (times) x (key labled x,t,n) in between the ALPHA and STAT keys
now press the zoom key and select #6 - ZStandard (this will give you a standard zoom)
You should see a parabola drawn on the screen.
If you enter in some equation and do not see it on the screen, you can try zooming out (zoom key) or setting up your display window, using the window key.
This is where it helps to know where your x and / or y intercepts are.
From there, you can use trace to move around the graph, 2nd+graph (table) to see your x and y intercepts.
Dec 22, 2010 | Texas Instruments TI-83 Plus Calculator
I want to graph a parabola on my ti-84. i entered the equation in y=, and then i turned on plot on, then i hit graph, but it is showing invalid dim. help please?
You're trying to graph a function that does not involve stat plot features but the calculator probably thinks you are. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Oct 29, 2010 | Texas Instruments TI-84 Plus Calculator
When I'm entering a quadratic function, I'm getting the graph of something that is not a parabola like it should be. However, when I graph x^2 by itself, it looks the way it should. What can I do to fix...
The actual graph depends on the constants (parameters) that are in the equation. Try playing with the dimensions of the window by zooming in or zooming out.
The most interesting part of the graph is the region near the maximum or minimum.
Here is a graph of the function y=X^2-5X 13 when drawn with standard window dimensions
Not very revealing. However if you press the Zoom key and select [2:ZoomIn] you see this (no changes) but the calculator is ready to accept your input concerning the new center of the graph.
At this stage, use the Arrow keys to move the center of the graph to another point as in the next screen capture.
Notice the new center as a sign on the screen and its coordinates at the bottom. By pressing [ENTER] you get this
If you keep Zooming in you may end up having something that does not look like a parabola anymore.
To summarize: Use the Zoom In or Zoom Out functions or find where the minimum/maximum is, center the graph on that point and modify the windows dimensions (Xmin, Xmax, Ymin, and Ymax) so as to get as much of the interesting part of the graph as possible.
Sep 02, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 graph problems-help please. Hi, sorry to sound so stupid, but trying for hours to try to solve these using my calculator,but doing something wrong as can't get the right answers. I wonder if anyone...
Parabolas
Open Y= editor and type in the two functions
The calculaus functions are accessible by pressing [2nd][TRACE] to open the CALCulate menu options. For the gradient (I think you mean the derivative) use option 6:dy/dx. But first choose the point where you want it calculated (use cursor to move along the curve) and press ENTER. The value of the deivative will be calculated at the chosen point.
The vertex of the parabolas are maxima. Thus you must use option 4:maximum
You will be prompted for a left bound. Move cursor to the left of the maximum (not too far) and press [ENTER]. A fat arrow is displayed on the graph that shows the left limit of the interval. You will be prompted for a right bound. Move cursor along the curve to the right of the the vertex. Press ENTER. A seconf fat arrow will be displayed to show the right limit of the interval.
You will be prompted for a guess of the maximum. Move cursor newar the max or enter a numerical value and press ENTER.
The location of the vertex is displayed (X and Y values)
I have no idea what you mean by the equation of symmetry
Intercept.
May 02, 2010 | Texas Instruments TI-83 Plus Calculator
How to graph an equation on a t1-83?
how to fix window to graph Pythagorean property
Sep 01, 2009 | Texas Instruments TI-83 Plus Calculator
How do I graph parabolas?
Parabolas are forms of the base equation X^2. So press the [Y=] key, and then type in the variation of x squared that you want
May 11, 2009 | Texas Instruments TI-83 Plus Calculator
Graphing parabola
Parabolas are forms of X^2. Go to [Y=], then put in the formula of the parabola that you want.
May 07, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
139 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
