Question about Dell OptiPlex GX270 PC Desktop
I have a dell inspiron 1520 the power cord is plugged but it says its not charging
  • 146 Answers
You may need a new battery
Posted on Aug 06, 2010
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I have an dell inspiron 1520 laptop that will not turn on. battery is fully charged. What should we do?
Do one thing, remove the battery from the laptop, connect to AC Power directly with out connecting the battery, then try to switch ON the laptop. If it got switched ON then there is problem in the Battery. If not it may be problem in the Power button or in the Mother Board.
Jan 14, 2011 | Dell Inspiron 1520 Motherboard
My dell inspiron 1520 does not work at all, power
no this is not a defect this would indicate that the power supply has failed on your pc.. look at the back of the unit if the power supply light is amber in color or blinking thne there is your issue.
May 13, 2010 | Dell Inspiron 1520 Motherboard
My dell inspiron 1520 does not work at all, power light is on for few seconds, then nothing happens, is this a factory defect?
have you tried chsrging it up by plugging in for a long period, make sure the cable to the transformer is actually plugged in securely they tend to work loose and look okay but arent.
Mar 21, 2010 | Dell Inspiron 1520 Motherboard
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
My screen on my dell inspiron 1520 has gone black
You've lost your desktop display.
The first thing I would do is to start the computer in safe mode. Once there, do a system restore back to the time that it worked.
I would also, just to be safe, do your disk management tasks like checking your hard drive for errors and running defrag.
Oct 22, 2009 | Dell Inspiron 6000 Notebook
I have a dell inspiron 1520 that is 15 months old doesn't go on
Generally, if the AC adapter for the system's LED goes out when connected to the system, check the battery and see if it is holding a a charge (Press the button next to the LEDs on the battery see if all 5 light up)  If the battery still has power, then most likely there is a failure of the motherboard.
If you can, try another Dell D-series AC adapter and see if the same thing occurs.  If the system powers on, replace the AC adapter, if not it is a motherboard.
May 19, 2009 | Dell Computers & Internet
Power chord won't charge laptop
If you need to wiggle the cord in order for it to charge, then you have a problem.
If you have to wiggle it at the computer, you probably have either a bad plug on the adapter or the power connector on the motherboard is going bad. This situation will not cure itself. It will only get worse.
Check the voltage at the end of the power adapter cord (the plug where it goes into the computer). If it's constant even when you wiggle the plug, you're gonna be looking for a new motherboard soon. I have actually replaced the power adapter on motherboards, but it's tricky--you have to be really good with a soldering iron!
Mar 22, 2009 | Dell Inspiron 1525 Notebook
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Dell OptiPlex GX270 PC Desktop Logo
60 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
