Question about Emerson (025806803716) Wine Cooler
Emerson wine cooler model FR48 does not cool. Temp indicators can be changed up and down and a few components light up. Fans do not operate. Suspect bad circuit board 0757-83835018. Where can I get a replacement board and at what nominal cost?
5 Suggested Answers
  • 3 Answers
SOURCE: Emerson FR24RD Wine Cooler
If you are handy with small electrics, or know someone who is...
I had a similar problem and just solved it.
My cooler was leaking and had trouble keeping the proper temperature.
It was also making a buzzing sound which is what lead me to my solution.
BTW - The liquid that was leaking was condensation, probably because the unit was not holding a constant temperature.
Unplug the unit first - no need to get electrocuted.
These units use peltier cooling- essentially a large heat sink with three fans attached.
Click here for more info regarding peltier cooling.
The peltier unit is not repairable, but the fans are; which was what my problem was.
There are three fans on this unit, one on the inside and two on the outside.
Follow these steps to remove them.
  1. Remove the rear cover. It is held on with ten screws. This exposes the two exterior fans and the peltier heat sink
  2. The heat sink is held on with four screws - remove them and pull the heat sink out. The third fan is on a short wire lead, so be careful when removing the heat sink from the body of the cooler.
  3. The two exterior fans are connected to a control panel, the electrical connection is easy to disconnect.
  4. Once all of the wires have been disconnected, you can remove the fans from the heat sink.
  5. The fans are screwed to a mounting plate, which is screwed to the heat sink
  6. You must remove the mounting plate first to expose the screws that hold the fan to the mounting plate. The fans are typical computer case cooling fans
  7. I only needed one fan, but replaced all three because I didn't want to do this job again.
  8. I purchased my fans from Newark.com the prices were better than what I found at the computer websites. Also, these fans are much better than the original and will hopefully last much longer than the three I got from the old ones.
  9. You need one of these and two of these. The total with shipping was around $30
  10. You will need to splice the old electrical connection sockets onto the new fans using wire crimpers or solder them on.
  11. Attach the components in reverse order and power on the unit.
  12. These fnas may move more air than the originals, because the unit seemed to cool much quicker than I remember.
  13. Total time for repair is about 45 minutes
Hope this helps and Good Luck
Posted on Jan 16, 2009
localwonder
  • 6784 Answers
SOURCE: Need user manual for Emerson Wine Cooler FR23RD
HI. i couldn't find the FR23RD but, i have been told that this manual covers your model. It basically covers FR24SL threw FR24RD. Your model is also covered in this edition. Click to review your manual.
Please rate and god bless.
Posted on Mar 22, 2009
  • 79 Answers
SOURCE: are both fans in back of wine cooler supose to
when coil gets hot fan sould come on to cool coil
Posted on Apr 11, 2010
SOURCE: wine cooler Doesn't work
I had the same issue with a bottle cooler, the power supply did not work at all. I found out that the transistor E 616 13005-2 is in fact a MJE13005 which is a common NPN power transistor, very easy to find (farnell.com).
Posted on Jul 07, 2011
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
How do I get a PCB70323E1
Have you looked at the back of the board for burn outs?
Jan 17, 2015 | Emerson Fr24sl 8 Bottles Wine Cooler With...
I have not been able to find any solutions online and apparently neither has anyone else. Clearly the Emerson FR48 wine cooler is a piece of $#!%. It appears the power supply on these is flaky. I can hear...
check the fam to make sure it spins freely ,, a little wd-40 could help, If the power supply is straining to make the fan move, you will hear that whining sound as its over loading
May 29, 2011 | Emerson (025806803716) Wine Cooler
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Emerson (025806803716) Wine Cooler
Nov 26, 2008 | Emerson (025806803716) Wine Cooler
Emerson (025806803716) Wine Cooler Logo
394 people viewed this question
Top Emerson Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Emerson Furniture Expert? Answer questions, earn points and help others
