Question about Kenmore 64802 Top Freezer Refrigerator
Water in the refrigerator There is water build up inside the refrigerator
  • Kenmore Master
  • 1,606 Answers
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Aug 04, 2010
Water/ice build up in center column of fridge
clean the backside fins of the fridge..they get gummed up with dust and cannot cool the water effectively..clean inside and especially outside back and bottom..also..defrost it fully first..
Jan 08, 2014 | GE Refrigerators
Water building up inside
Could have a loose hose for the water despencer or a cracked waterline. There is a water drain hole at bottom of refridge. Make are that is not clogged also. Should not have a water build up unless you are defrosting your freezer section or the freezer section is not keeping up.
Nov 09, 2012 | Delfield 6076XL-S Stainless Steel Side by...
My water dispencer is driping water how would i fix that?
Hello, Self- defrosting refrigerators disposed of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan water normally evaporate. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment, then the water build up at the bottom, inside of the refrigerator. When the water has build up for a time it may spill out of the front of the door opening. To fix this problem, Clear the drain tube or channel and allow the defrost water to flow down to drain pan.
Thanks
Jun 21, 2010 | Admiral 26 cu. ft. Side-By-Side...
Water collects on the bottom of the refrigerator
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 11, 2009 | Refrigerators
Water dripping inside refrigerator
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 07, 2009 | Refrigerators
We have a GE profile that we bought in 2007. We
Hi Sandy, I can assist you.
Jun 19, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ice not being produced
hi there,
check to see there is any frost building up, either on the water line or the inside of the door.
if there is no ice build-up, you may have to have the water valve (inside the icemaker) replaced.
Aug 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool frig model -et9fttxlq11 serial-9m5110756 inside at very back water comes out of this opening
Your issue is;
"whirlpool frig. model -et9fttxlq11,serial-9m5110756
inside at very back water comes out of this opening"
Thank you for providing a valid model number!
This link shows exploded view of your model.
http://www.repairclinic.com/0100_2.asp
Water can leak from these areas:
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
    The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
    The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
    Please show your appreciation by rating my solution.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jul 24, 2008 | Refrigerators
    LG Refrigerator
    • the drain line in the freezer may be clogged forcing water to drip into the freezer. clean out the freezer and pour some hot water in the back of the freezer to unclog the drain.
    • another cause of this would be if the door is not sealing properly then the inside of the refrigerator will build up condensation.
    Jul 05, 2008 | Refrigerators
    Refrigerator
    I just fixed similar issue. Defrost drain plugged. Take back panel off and behind fan is back hose. Take it out from the bottom and use something like coat hanger to unplug.
    Also need to take off front panel from inside freezer and remove ice build up and thaw with hot water or hair dryer. Once done you should notice water in drain pan from back. Put all together.
    Feb 01, 2008 | Frigidaire FRS3R5EMB Side by Side...
    Kenmore 64802 Top Freezer Refrigerator Logo
    124 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
