Question about MSI Wind U100-016US Laptop
My msi wind will not operate on battery alone. Battery indicator shows that it is fully charged. While plugged in the battery light flashes orange
    President:
  • 567 Answers
Hi this kind of behaviour from the MSI mean the battery is dying it is loosing it capability to hold charge so,to solve the problem you should replace it.
Posted on Aug 04, 2010
  • radoofaceboo
    radoofaceboo Jul 21, 2012
    I have the same problem with a original brand new replacement battery...
  • radoofaceboo
    I have the same problem with a brand new original replacement battery. Usually it starts to charge normaly if I plug the power supply out and back in again.
Battery light flashes green 5 times, then changes to orange.
The flashing green indicator is telling you (and the notebook) that the battery is almost fully charged, but then by switching immediately to flashing orange, the status has changed to "battery charge is low". This is not normal behaviour and probably indicates a serious issue with the battery. My guess is that the charging is initiating some kind of rapid battery self-discharge.
Ref - Knowledge Base
Notebooks will power up and work without a battery just fine.
Ref - Laptop Battery Basics dummies
Try to operate yours this way. This will eliminate the battery from the loop as a potential cause of the BSODs you are seeing.
Jan 09, 2018 | Dell Latitude D610 Notebook
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Sep 25, 2013 | Gateway Computers & Internet
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2013 | Dell Inspiron 1420 Notebook
Battery light flashing orange
Your battery may have Battery charge status indicator, when you press the button next to the 4 led indicators the LEDs indicate the charge status.
Also the System Battery/Charge LED indicates the battery's current operational condition.
Flashing orange indicates Battery failure.
May 25, 2012 | Dell Inspiron Mini 10v Netbook Computer
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
MSI Wind u100 - battery LED flashing red
check for an update with windows 7 then go online to asus support or call them. They should have a solution for you.
May 12, 2010 | MSI Wind U100-053US 10-Inch Mini Laptop
My MSI Wind battery blinked out and not it is blinking orange what does that mean?
The blinking battery light indicates the battery has an internal short which is preventing it from charging. The problem usually goes back to the charge monitor circuit in the battery. There is a thermal fuse that blows if the battery pack gets to hot during a charging cycle to prevent the battery from exploding like to hear about on the internet from time to time. After the fuse blows the only thing to do is get a replacement battery pack.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 18, 2010 | MSI WIND U100 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
M670 notebook not charging when plugged in
Charge the Battery fully before first use . The red flashing indicator shows that the battery has been deeply or fully discharged . Please Connect your laptop to AC power source and let it remain for well over 10 hours atleast.If the battery pack is alive it might recover and start working normally.
Apr 27, 2008 | MSI Megabook M670-046US Notebook
MSI Wind U100-016US Laptop Logo
116 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
