Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Does not light, no sound,but rear fan works. I have no video cable connected as of now. Should I not see the screen light up and some noise from the speaker? What might be some possible causes and the probable costs. I hope I have given enough clues? Thanks!
  • 10,594 Answers
I need following info to diagnose problem in your tv.
Is it Sony KDF-60WF655 tv or any other model?
Do you see blinking power/standby red light on tv front? If yes, how many times it blinks after 3 seconds long pause.
How old is this tv and did you replaced lamp in last 2-3 years?
Thanks.
Posted on Aug 04, 2010
  • 12 more comments
  • shane514 Aug 06, 2010
    Sorry, I neglected the most important point and it is that the tv is a Sony KDF-60WF655. It was purchased February 2005. When I press the power button the green light blinks 4 times and the red light blinks 3 times.It keeps blinking this sequence of 3 reds. I'm repairing this for a friend who had it given to him and so I don't know if the bulb had ever been changed before. I have been reading a lot of comments concerning this model and the cost of the bulb which by the way is defective. That I know. Is it worth repairing? Thanks again!
  • Shahid Electronics
    Shahid Electronics Aug 06, 2010
    OK, if the red light label is Lamp on tv then tv needs Lamp replacement.
    and if red light is Power/Standby light then check lamp cover that has not been installed correctly because lamp cover push micro safety switch inside that tells system control that lamp cover is fixed correctly.
    Let me know your finding to fix this tv.
    Thanks.
  • shane514 Aug 07, 2010
    I took the lamp out before I did the test . I realized that from what you had said. So, I put the lamp back in and tried the test again and this time the Power/standby lamp just stayed red and continuously stayed red and did not blink.I never pressed the Power/standby button when I did this test. I guess this says that just the lamp is the problem, right? Thanks!
    Shahid Electronics Aug 07, 2010
    Yes, it could be lamp problem. What about lamp light on tv front? Does it lit solid?
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
I have a noise comming from the lamp area the fans are working fine i think it is the lamp do they make a noise when they are anout to break
hi,
if the sound is not coming from the fan then check the connections of ur lamp, if there is any loose contact in the connection there will occur a sound. also fan will produce some noise if its bearing have some problem. it will work fine but produce noise. the lamp will make noise at the starting time afterwords it will not.
ok
Dec 31, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Video and audio dont work
you may want to call sony. make sure that your ps3 is clean and dust free, that the vent doesn't have anything blocking it. make sure that your cables are connected tightly, in the rear of the ps3 as well as on your tv.
Jun 30, 2009 | Nintendo Game Boy Advance Console
Denon AVR 2106 clicking noise
I like when a user is observant and curious. That will help immensely in resolving this problem.
What source(s) are always involved with the problem?
You imply it is observable with output video to the TV - "only when there is movement on my tv screen and it stops in still screen". That sounds like a digital pathway problem of some sort as any data errors would eventually escalate to something audible or visible to you once the hardware and correction algorhythms are exhausted. The clicking inside the receiver could be its efforts to resynchronize with a bad data stream. Hence, I'd like you to isolate the ins and outs that fail all the time and find the probable single source of the problem.
Try this: put a digital source on and select/deselect it for listening or viewing. Does it make the click in that brief time it's 'thinking' before you hear the source? That would be the 'normal' sound. My Pioneer does it once per source switch. Repeated clicking would mean it's struggling.
I'm betting you have an optical or hdmi cable that's flaky or not in tight and straight. Or, if only one extternal source is involved we follow that back.
Apr 29, 2009 | Denon AVR-2106 Receiver
The blue and green light and the fan come on but it keeps saying
This sounds like a cable issue. I would make sure everything is connected correctly/securely and if that doesn't work I would try a new cable. If it isn't the cable you can return it for no cost other than gas.
Feb 05, 2009 | Sony Playstation 3 (PS3) Console
Dell inspiration 1150 laptop
sounds like screen is blew out try rebooting it with orther screen get back to me lala linda
Apr 25, 2008 | Dell Inspiron 1150 Notebook
19 in blue screen only sound works great
blue screen is the noise mute screen. however the audio is not getting muted and hence the buzzing....meaning the tuner on the TV is not getting locked on to the station/frequency
1. check your antenna if you are using one. Autotune
OR
2. Reconnect coax from the cable box to Tv and autotune.
OR
3.Use the Video out from the cable box and connect it to one of the video inputs on the TV. Switch your Tv to that component. Use the cable box to change channels (Best case scenerio)
Feb 28, 2008 | Westinghouse SK-26H240S Television
WD-52725
if you get a blue screen than your lamp is working fine. blue screen is considered "video mute" it display that blue if the tv thinks there is no video. try to reset the tv by pressing - menu 123 then reset to system defaults.
Feb 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
