Question about Viking Freezer DFFB364L
My ice maker drips water after filling the cube trap - on one side only and creates a little ice mountain on one side of my ice drawer. I see where the water is dripping, out of the bottom of the mechanism that connects to the trap. It could be coming out of a hole in the bottom left of the tray, but not sure - cannot see that. Or it could be dripping straight down from where the water comes in to fill the tray. Can I fix this myself?
  • april_summit Aug 06, 2010
    This sounds like good advice. I will give it a try before I call a repair person.
    Thanks for the help!
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link…It is suggested to set the water level adjustments….
http://www.davesrepair.com/DIYhelp/DIYicemakertips.htm
http://www.geappliances.com/service_and_support/faqs/faq_icemakers.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 06, 2010
French door / lower freezer. The icemaker makes ice fine until tray is about full and then slowly drips water until about 1/8 of ice is frozen together with a upside down brown ice cycle fused to them....
The most common reason for this is that the fill valve for the ice maker is sticking slightly.
The brown ice comes from the leaking water sitting there on either the kickout bar or the gears and you are getting some residual rust deposit.
You will need to take the fill valve apart and clean it or possible replace it, I also recommend installing a water filter for the ice maker if you don\'t have one or replace the old one.
Calcium deposits in water are real hard on these small valves.
Oct 10, 2013 | Jenn-Air Freezers
Ice maker will not separate ice cubes
Check if your water filter is up to date, if not check if the ice maker has the option to choose the side of the ice cubes, if so, set it up to medium side.
Apr 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Apr 05, 2009 | Whirlpool Freezers
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
LG ice maker only fills half of the cubes
On the ice maker you will see a little screw with a + or - printing check carefully on the side just turn it on the way of + it will increase the water time so you will have bigger icecube. hope i was helpful!
Francois
Jun 22, 2008 | Freezers
Viking Freezer DFFB364L Logo
23 people viewed this question
Top Viking Freezers Experts
Gil Shultz
marlin siecinski
Dan Apthorp
Are you a Viking Freezer Expert? Answer questions, earn points and help others
