Question about Honda Garden
How does one replace/adjust the drive belt on a honda harmony II mower
5 Suggested Answers
  • 109 Answers
SOURCE: Honda Harmony mower, self propelled hydrostatic,
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Posted on Apr 26, 2009
  • 59 Answers
SOURCE: Have honda harmony 11 HR 216 that stopped being
it has a belt look under the mower
Posted on Jun 26, 2009
mowerman1857
  • 389 Answers
SOURCE: Honda Harmony II HHR216 Governor Surge
You have dirt and/or moisture in your carburetor float bowl. Remove the bowl, clean it out, remove the main jet and clean it out and you should be good to go
Posted on Sep 14, 2009
consaka
  • 661 Answers
SOURCE: Oil coming out of the carburetor of my Honda Harmony 215 mower
It could also be overfilled with oil. I am working on one right now that someone overfilled with oil and all it does is chug and miss every other stroke making it an 8 stroke.lol. the filter is soaking wet with gas and oil I bet it runs fine soon as the air filter is removed.
Posted on Nov 29, 2009
How to adjust the Governor on Honda Engine
Automatic governor. Replace or rebuild carb. Ensure float is functioning properly..
May 30, 2014 | Honda Genuine oem harmony ii hrr216...
Honda push mower
NEED BELT DIAGRAM FOR RANSOMES 956105 DECK
Jun 20, 2013 | Garden
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
Honda Harmony self propelled not propelling. Belt is fine. Cant find adjustments
Do you know for sure that the belt is not stretched. Make sure also that it is on the pulley correctly and the pulley is spinning with the shaft you also might have spun a key.
Oct 08, 2009 | Garden
Honda Harmony II HRR216TDA drive clutch cable snapped. Need advice on how to access transmission box to change cable. Owner's manual does not address this level of repair and schematic obtained from local...
First put the machine on the side with the muffler facing the floor . Right behind the rear wheel you have a 10mm bolt that you have to remove and look for another 2 10mm bolts holding the plate that you remove the first bolt (one should be at the bottom and the other one on the side) .
Slide that plate out of the machine and now you be able to see the belt that goes to the transmission and also the drive clutch cable.
Hope this help .
Aug 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have an older Harmony II HRT 215. The drive
the best thing to do is take the model number and order a belt from honda which will be the right size and thickness
Aug 09, 2009 | Garden
Garden Logo
318 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
