Question about Roper RS25AEXLQ Side by Side Refrigerator
Help locating water and ice filter - Roper RS25AEXLQ Side by Side Refrigerator
  • Roper Master
  • 1,606 Answers
The filter is located in the top right rear of the refrig compartment . Filter pt # 8171413
Posted on Aug 04, 2010
When I changed my filter in my Whirlpool refrigerator, my refrigerator stopped making ice and dispensing water. How do I get it to start back making ice and dispensing water.
If you still have the old filter replace the new with the previous. If all works OK check new filter for blockage or manufacturing defect. Usually most units will work with no filter installed.
It is likely that you have not fully assembled the new filter in the location.
The filter can be removed and there should be no leak and the ice maker and water dispenser should work just like before except the water is not filtered. This feature is available for customers who have whole house filters.
Hope this helps?
Nov 22, 2016 | Whirlpool Refrigerators
Why won't the water come out of the in-door water dispenser? Why won't my ice maker make ice?
Be thoughtful of any water leaks. Water leaking beneath the machine will damage floors.
If both the ice maker and water dispenser are not working it is likely the feed connection from the wall to the unit. The hose/ copper tube can get kinked or the valve at the connection at the wall internally plugged. Close off the water at the wall and using a catch remove the connection at the unit open the valve at the wall and confirm the that water flows freely through.
Check the filter of the water located usually at the front grill near the floor. If the filter is removed the water connection will buipass the filter.
It is not likely with both the ice maker and water dispensor that both electrical solenoid valves have failed.
26159659-bocfglvi4lojepqiax35xhd0-1-5.jpg Hope this helps?
Apr 10, 2016 | Kenmore Refrigerators
Replaced water filter but still not making ice
need to replace the water soleinod valve it's located under around the compressor section usually it's a blue color twin relays one for the water dispenser and one to the ice maker...good luck
Jul 08, 2015 | Maytag MSD2756G Side by Side Refrigerator
How do I change water filter
Hello Anita;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, so I am going to have to tell you where the water filter might be.
1.) On the lower, front bottom grill or toe plate, in the center there is a round hole. In this hole is your water filter. Grab the end of the cylinder and turn 1/4 turn counter clock wise and pull out. There will be some water in the filter. Slide the end cap off the old filter and slide it back on the new filter. Insert the new filter, push in and turn 1/4 turn clockwise.
2.) In the upper back right hand corner of your refrigerator section is where your water filter is located. There is a plastic cover plate around it, but you can still see the bottom of the filter canister. Reach in and turn the bottom of the filter 1/4 turn counter clockwise and remove. Insert the new water filter and turn 1/4 turn clockwise.
After installing a new filter, there is air in the filter. Run your water dispenser until a steady flow of water come out. You will get air & water spurting out.
If you only have a ice maker, you will have to manually cycle your ice maker until it fills.
The water filter change light is not tied into anything in your unit. It is like a egg timer. Even when the indicator light indicates to change you water filter, you only change your water filter when either the water coming out of the water dispenser is slow or you are getting small ice cubes.
Nov 23, 2014 | Kenmore Refrigerators
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Where is the water filter located
The water filter should be located in the back right hand corner of frig compartment.Just unscrew and it should drop out. hope this helps
Jul 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Cannot locate water filter
From my experience the water filters for most refrigerator are near in the area of the Ice maker cubical.
Jul 16, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
Ice tastes bad from ice maker
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
Apr 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Roper RS25AEXLQ Side by Side Refrigerator Logo
59 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
