Question about Black & Decker Quick N Easy X420 Iron
Switch will not sstay on. - Black & Decker Quick N Easy X420 Iron
Tefal pro express steam generator iron. When in use the handle gets really hot. I have to put a cloth around it to use. Help.
try to reduse the temperature setting first, if it still does the same then the thermal switch mechanism is not cutting off the switch at proper temperature
need to replace the thermal switch mechanism
Oct 23, 2017 | Tefal Irons
On off switch broken, how to fix?
The switch is an obsolete part. The part has been discontinued and no longer available. You cannot fix the switch. It must be replaced.
Jun 08, 2014 | Rowenta DG-980 Iron
Unable to switch off the iron why?
Switch went bad. Replace switch.
May 07, 2014 | Irons
How to hardwire rowenta powerglide to bypass safety switch
lancell - you're an idiot...of course he understands - that is why he is asking!
Sep 24, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Burning smell
thermal switch is not working...upon reaching a certain temperature limit it should switch off then switch on again after a moment to maintain the set temperature..what happened here is that your thermal switch didn't switch off so the temperature continue to rise to the extent that the heating element burnt and smell like that..adjust the setting in such a way that it switches off after reaching the desired temperature..
Jun 18, 2009 | Rowenta Irons
No audio is coming at all in my philips 29 inch Hi-fy tv.
If you have a provider box it also has a volume control,manully turn your tv up and use your controller to turn the box up.
let me know
Jan 30, 2009 | Philips HI-296 Iron
Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Feb 25, 2008 | Euro-Pro Steam Generator EP8001 Iron
B&D steam xpress 660 faulty switch to replace
I'm not familiar with your particular model , or Irons themselves.
So forgive me if im wrong ,
I think it could be a safety feature , to prevent accidents, so replacing the switch will most likely make no difference.
But if you still find yourself needing to Iron sideways , possibly whilst extreme bungee-jumping or entering the earth's outer atmosphere !! LoL sorry couldn't help myself there , you could try phyically bypassing the switch itself.
There would be two main ways to approach such a task, depending on the cut-out system utilized by the iron.
[u]Electrical diversion[/u]
Usually safety cut-out switches will interrupt the power of one polarity only, either positive or negative. especially where water is involved. This is easily bypassed by simply joining the matching 2 wires together either side of the switch to complete the circuit making the safety switch obsolete. There may be other wires for indicator lights ect which are better left alone for now.
[u]Mechanical diversion[/u]
The iron may utilize the water or other moving component to interrupt the power supply .Such as a water level indicator in a kettle, which is positioned to activate only when in sideways position. Again you could bypass the wires as above or bind the mechanism to prevent the movement being possible.
If it does use the water method , running the iron with no or low water in it may work...But there's probably a safety feature for that too....LoL
Anyways hope it helps you out a little
Feb 06, 2008 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker Quick N Easy X420 Iron Logo
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
