Question about Car Audio & Video
Have a 1500watt crunch powerzone amp, 2 square 12" hifonics brutus, and 2 round 12" rockford punch. had it 4 months and today it started a loud humming when i turn my bass control up. what could be causing this?
4 Suggested Answers
duby1990
  • 370 Answers
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Posted on Feb 06, 2009
  • 1114 Answers
SOURCE: when my bass hits, my car lights flicker.
Is the problem much more noticeable when the car is at idle? Double check that Alternator output. 70 amps is not high output, and if the problem is especially noticeable at idle, it's probably due to the alternator putting out lower voltage( a common thing with alternators). Also, with that much draw from your sub amp, the wire from battery to alternator should be beefed up, as well as the ground wire from battery. You can make up your own cables by purchasing the wire to length and wire lugs at a local Welding shop, 4 gauge from alternator to battery is good. High output aftermarket Alternators shoot into the 200 amp range.
Posted on Aug 20, 2009
  • 63 Answers
SOURCE: i have 2 12 inch
Short answer: NOPE!
The Hifonics Brutus 2100 is stated to produce 2100 watts RMS @ 1ohm load. Most amplifier manufacturers overstate their claims. The 2100 watt output is most likely at 14.4 volts and not the 12.6 volts your car will actually be providing the amp.
But, even if the actual output was 2100 watts that would be 1050 watts to each 12w7. The 12w7's are rated at 1000watts RMS and 2000watts peak. As a MECP certified installer, any system I have done using 12w7's have had a MINIMUM of 1000 watts being provided to each speaker. My personal preference is to run 1500 watts each and keep the gains adjusted lower on the amp. Thus allowing the amp to run cooler and allow the additional headroom for those "show-off" moments!
Posted on Dec 22, 2010
Brutus elite hifonics BRE1600.1D. Not as powerfull now.
Make sure of voltage going in to Brutus.
Mar 23, 2014 | Car Audio & Video
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
Have 2 blown square hifonics 12inch speakers. Was playing goos and then just stopped. Took to radio shop and they said I have 2 blown sub-woofers. How can i get them fixed.
They probably will have to be reconed. Slight chance the flex leads have broken in which they MIGHT be repairable. If this occurred during playing very loud, you probably burned up the voice coils.
Have them reconed and then use an amplifier that maxes out at MUCH less power to drive them. Also fuse the speakers to protect them.
Dec 04, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
I am ordering 2 pioneer TSW307D4 or D2 is a 2400 watts amp good?
ok theres a amp called slugger they came out about 7-10 years ago its small but very very powerfull i was picking up my 2 15 inch l7 kickers i drove from my house to vegas with no problem about 4 and a half hrs and didnt turn off ,on the other hand i had my fosgate wich i love t1000 wich turned off on me a couple times
Mar 15, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
No sound to speakers
is the sub dual or single?check sub first then try disconnecting all power including ground for 20min to discarge caps some amps mute if driven hard at low impedience .
Jul 01, 2007 | Hifonics BX1500D Car Audio Amplifier
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
