Question about Eljer Toilet Onepiece Canterbury 081162047
The water kept running after finished flushing and tank gets full. The floater is at a right height. Replaced the rubber flopper. I can see that the water is running into toilet bowl from small holes on the inside ring of the toilet. How can I solve this problem?
  • 43,501 Answers
Either you did not get the right flapper or you have a crack that is letting the water through even though the flapper is sealed...
Cracks can be very hard to identify, but if the flapper is sealing good then that's your problem...
heatman101
Posted on Aug 05, 2010
Our WaterRidge toilet tank will not fill with water
This sounds like the float is getting stuck , while the toilet is trying to fill if you see the float ball that is attached to a arm that pivots , if you lift the float up it should turn the water flow off from trying to fill the tank , some problems that can stop this are the rubber seal that lifts up when you press the flush button to allow water to flush the bowl does not seal back in a position so that the tank can never fill , sometimes the float ball can get stuck which stops it from rising up with the water level and shutting off the water , but my best guess is that the rubber seal has started to perish or distort and needs to be replaced you can find this right at the bottom of the tank and it is directly connected to the flush button ,so if you inspect inside the water tank and press the flush button you will see that it opens up and lets water pour into the toilet bowl but if a tight seal can not be made water will never fill the tank
Sep 26, 2017 | Washing Machines
Needs two flushes to empty bowel
might be that the water level in the tank is to low. if both buttons release the same amount of water then you have to increase the water level in the tank by adjusting the height of the floater on the inlet valve. look inside the tank and there should be a WL mark meaning water level should be set to this level minimum.
Nov 30, 2013 | Pfister VTP-E70W Kamato One-Piece Dual...
Running Toilet
Sounds like your flush valve is shot. They are not that expensive and can be easily replaced.
Overtime the rubber in the flush valves break down and need to be replaced. Easier to replace the entire valve than fix the old one.
Semper Fi,
Z
Apr 30, 2017 | Home
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
Replaced the seals because it was running. Water is still leaking from the tank somewhere so it keeps refilling....it's constantly leaking and refilling. how can I repair this.
You say you have replaced seals. I assume that you are refering to the flaper valve that controls dumping water from tank to bowl to flush. To make sure you have a good seal put a dozen or so drops of food coloring directly into tank when it's full and observe for a hour or so to see if water in bowl is discoloring. If it is then you are still leaking there. You can shut off water supply off or flush toilet and manually hold flush valve closed. Check to see if there are any rough spots on flapper seal that could stop flapper from sealing good. If you find rough spot then make sure the surface is dry and sand lightly with medium grit sandpaper.120 grit or finer.
One other thing to check is if your toilet has the plastic or rubber tube that goes from the flush valve into the overflow. Make sure that this tube does not set below water level in tank when it is full as this can create a suction or syphon,
Hope this helps you. Thanks
Jan 10, 2011 | American Standard Home
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Toilet keeps running even when manually lifting floater to max
check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Oct 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Unit collects water but periodically continues running despite full bucket which is flush in unit, what could be causing this it doesn't happen everytime.
there is a floater switch on the machine over the bucket (and sometimes in it). the floater tells the machine that the bucket is full. if the floater is stuck, the machine will assume that the bucket is not yet full, and will continue to run. check that floater switch with the bucket out. you may need to press in the bucket switch so the machine thinks the bucket is in. then lift the floater and see if it stops running. if not, the switch is bad.
Jul 29, 2009 | LG LHD45EL Dehumidifier
Not enough water in the toilet bowl
Adjust the floating stopper in the tank to allow more water to fill the tank
Oct 29, 2008 | American Standard Flowise 2480.216.020...
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
233 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
