Question about Ruud UBHC Air Conditioner
My downstairs Ruud AC will not blow any cold air. The fan in the outside unit does run.
  • 674 Answers
Is the compressor running in the outside unit? If it is then check the capacitor for the fan and replace if necessary. If it's good then check the fan motor. If the compressor is not running also, check the circuit breakers or fuses and the contactor in the outside unit. Let me know what you find or if this helps, please rate it.
Posted on Aug 05, 2010
  • Donald Jordan Jun 10, 2014
    Irrelevant...the fan runs...208-230 is present.
    To correct.....on a RUUD, RHEEM or similar unit, the red wire tends to corrode and burn off on the compressor terminal. I'd start THERE.
I have a ruud ubhc-17j11sfd that does not blow cold air. it blows room temperature air only. the unit seems to run ok and the outside fan runs ok also. The filter is cleaned and the thermostat is set to...
Hello, if the airflow seems good and the unit is clean it is possible that the unit has a low refrigerant charge due to a leak, if you have a thermometer measure the return air and the supply air, tjen find the differance between the two, if it is below 15 then the unit is undercharged and will neec to be recharged.
Jun 15, 2011 | Ruud UBHC Air Conditioner
My AC unit stopped blowing cold air. Everything is on and running including the outside unit. I tried to turn off the thermostat, but it will not turn off. The read out shows a fan blowing with the word...
You can remove the face from the thermostat and see if that stops it. If it does the problem is in your thermostat. If it doesn't then a contactor or relay is stuck. Let me know what you find and I will offer more suggestions.
Sep 25, 2010 | Ruud Heating & Cooling
AC on but nothing coming through vents
the therostats adjust a damper to open air flow . it could be a damper motor problem. or it could be the ajustment of the tstats. turn the up stairs up then go to down stairs turn it down. then see if the air is flowing. i hop this helps
Apr 15, 2010 | Ruud UAKA037 Air Conditioner
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
COMPRESSER IS VERY HOT, FAN OUTSIDE BLOWING COLD AIR OUT NOT HOT
Most likely the unit is low on refrigerant. You could also have a restriction in the system. You need to put gauges on the unit.
Jun 14, 2009 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
178 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
