Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
GE Profile Arctica PSS25SGNABS stopped cooling. Also there is a burnt smell when we got up this am. No power to icemaker. Lights come on in main section but controls do not show temps, etc.
  • 42 Answers
SOURCE: I have a GE Profile Arctica. Refrigerator side
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Arctica PSS25SGNA BS Icemaker is not
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Posted on Nov 18, 2009
  • 288 Answers
SOURCE: GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Posted on Nov 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: I'm unable to set GE Profile Arctica ridge to recommended temp
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
Posted on May 07, 2010
SOURCE: my ice maker will not work, Ge profile Arctica.
ICE MAKER MAKES ICE, DISPENSES WATER BUT DOES NOT DISPENSE ICE WHEN HANDLE IN DOOR DEPRESSED. REMOVED TRAY FROM FREEZER, WASHED ALL ICE OUT OF TRAY AND CHECKED ROD FOR FREE MOVEMENT REPLACED -TRAY--- STILL DOES NOT WORK..
Posted on Dec 30, 2010
GE Profile Arctica not making ice
Check to see if the fuse for the icemaker is blown. Check to see if the linkages are moving. Check the activation motor is getting power.
Jan 20, 2013 | GE Profile Arctica Customstyle...
Ge profile arctica side by side- ice maker and water dispenser not working..have already replaced the water filter
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Jan 11, 2010 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
GE PRofile Arctica
Just had mine with the same problem fixed today,it was the main board on the rear of the fridge,common problem with these models told by the tech.
I believe you can get a free board fom ge but you pay labour
Jun 17, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
May 29, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
207 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
