Question about Canon PowerShot S2 IS Digital Camera
When my S2 IS is turned on, the lens moves out, a beeping sound occurs, but the viewfinder remains black except for the message E 18. The lens does not move back in when the off button is pressed.
    Novelist:
  • 178 Answers
The Error E18 is quite a havoc on these Canon cameras. Here is a blog with great info on it: E18 Blog
Do not force your lens back into place and don't try and jiggle it either, you will be further damaging other pieces.
This camera is very powerful and the repair is well worth it. Teleplan Camera Repair provides a quote online with the cost clearly displayed.
Posted on Aug 04, 2010
My Canon EOS Rebel T2i EF-S 18-55 IS Kit 18MP Digital SLR 4462B003 USA Model will not come on. What is the possible problem?
It's probably coming on but the button has been pushed to activate the viewfinder so all information gose there and the LCD screen remains black OR because this camera has an interesting feature just under the viewfinder that scenes the photographer looking into the viewfinder automatically shuts off the rear LCD screen. If this sensor is blacked then the LCD screen will not come on.
May 12, 2011 | Canon EOS 550D EOS REBEL T2i Digital...
When I turn the camera on and look through the viewfinder, it's black. Also, if I flip open the little screen, it is black. It does show the little icons, but it's as if the lens cover is still on (which...
I have the exact same problem.
It started with the recurring "change batteries" problem - which was solved by using non-rechargeable batteries.
Now everything is working fine except there seems to be no light coming through the lense. Everything except reviewing mode is black and all my pictures are completely black. I dont know where the problem is. Could be the ccd. Might take this to the camera shop but im expecting it will cost over $100 to fix... any help?
Jan 13, 2011 | Canon PowerShot S2 IS Digital Camera
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
Canon s21s
Think that you mean the S2 IS? If so, Canon has not yet to offered an advisory repair of that particular problem (although many people think they should as this seems to be quite a common problem for the S2). There are however some simple things that you can try to revive your camera from the likely "stuck shutter" problem that you're experiencing. See this blog article.
Sep 27, 2009 | Canon PowerShot A75 Digital Camera
Camera turns on, lens goes out, but it is black, see nothing through it or on lcd screen (yes, cover is off). There is no error messages, still takes pictures but just black. Can view previous pictures on...
It coud be a very common IRIS/Shutter stuck problem...this has been reported on lot of S3 IS & S2 IS cameras... just search for this on web and you'll find a temporary solution also (related to taking battery out in the middle of taking picture during a long exposure (15" in Tv mode), but for more permanent fix you need take it back to Canon service center
Aug 03, 2009 | Canon PowerShot S3 IS Digital Camera
I can turn my camera on but the lens if out and it does nothing.
Check out the following:   Generic problem for all Digital Cameras E 18 problem
Dec 30, 2008 | Canon PowerShot S2 IS Digital Camera
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
No picture on lcd & view finder
PLease see http://www.fixya.com/support/t131881-sony_cam_recorder_wont_record for more information on this i have had the same problem, faulty CCD image processor chip.
Apr 01, 2008 | Video Cameras
E 18 Message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 21, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
131 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
