Question about HP L1702 17" LCD Monitor
HP 1702 monitor pin-outs
Got a broken VGA connector and want to replace it but need confirmation of the pinouts as the original connector wiring is a mess!
Thanks for your help!
Victor Van Neibaus
  • ByronD Dec 21, 2008
    hey there
    i have problem with my hp 1702
    if you dont know the problem with it is that in the rear of it...the vga connector does not come out..i think its perminantly stuck there..
    and i ahve damamged the cable...what can i do?
    plz help!!
    Problem Solver:
  • 6 Answers
Okay...after a bit of trawling the net I found an almost correct pin out. It was not identical to my broken connector however after a bit of checking, I found that all the screens on the cable were common so I wired the connector as follows and all was well! :- 1 Pink 2 Grey 3 Light Blue 4. Violet 5. Link to 6,7, and 8. 6. as above plus a link to the drainwire next to the foil screen. 7. Link to 8,6 and 5 8. Link to 7 and 6 - just use some solder! 9 Dark Blue 10. Red 11. Black 12. Brown 13. Orange 14.Yellow 15 Green I used a diecast 9 way backshell and tied the cable braid screen to that so everything properly screened. Plugged it in and away it went! Hope this is helpful in the future. Best regards Victor.
Posted on Apr 27, 2008
Hi my laptop went in for repair and they said it cant be fixed as the vga isnt working? what is this and could it be solved
A Video Graphics Array (VGA) connector is a three-row 15-pin DE-15 connector. The 15-pin VGA connector is found on many video cards, computer monitors, and some high definition television sets. On laptop computers or other small devices, a mini-VGA port is sometimes used in place of the full-sized VGA connector.
DE-15 is also conventionally called RGB connector, D-sub 15, mini sub D15, mini D15, DB-15, HDB-15, HD-15 or HD15 (High Density, to distinguish it from the older and less flexible DE-9 connector used on older VGA cards, which has the same shell size but only two rows of pins).
VGA connectors and cables carry analog component RGBHV (red, green, blue, horizontal sync, vertical sync) video signals, and VESA Display Data Channel (VESA DDC) data. In the original version of DE-15 pinout, one pin was keyed and 4 pins carried Monitor ID bits which were rarely used; VESA DDC redefined some of these pins and replaced the key pin with +5 V DC power supply.
the only solution for that is to replace your vga.
May 31, 2011 | Computers & Internet
How to repair HP 1702 lcd monitor with broken VGA cable
u can cut 15pin vga socket and u can replace with new
Jan 22, 2011 | HP L1702 17" LCD Monitor
VGA problem with HP monitor
The VGA cable are standard pin out for VGA DB15HD connector.
Learn about it here:
Apr 02, 2010 | Computers & Internet
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of
Aug 29, 2009 | Computers & Internet
Black screen on my desktop, and connect pins are broken & bent
You'll get either no signal or missing color(s) if pins are bent or missing.
Carefully bend pins back with small needle-nose pliers. Pin 9 is missing by default - if any other pins are missing or broken, you'll need an expert to wire a new VGA plug.
May 22, 2009 | E-Machines eMachines Desktop PC
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
More monitor pinouts,
Apr 21, 2009 | KDS K717s 17" LCD Monitor
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Apr 02, 2008 | Computers & Internet
HP L1702 17" LCD Monitor Logo
616 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
