I am installing a weil-mclain ultra 105 (series 3) natural gas boiler with a ultra plus 40 indirect fired water heater. The system has four zone valves and three circulator pumps. I can find no wiring instructions for the zone valves, thermostats, or a relay for this system. How am I supposed to wire the system?
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: weil mclain heII-4 short cycles burner comes on
Make sure the exhaust fan is pushing out hot air and not obtstructed. Check the pilot assembly, clean ane make sure the sensor is well into the flame. Watch the flame to see if all burners are igniting. If not, clean the burners and the flame tray that spreads the flame to all of them. Look for a sensor at the farthest burner and make sure the probe is free of carbon and the wiring is tight.
Posted on Nov 08, 2009
SOURCE: I have a Weil-McLain hot
Hello.Prob#1 valve has a bad END SWITCH,change the power head,thad brings the circ on when open.Prob#2 try manual overide lever.iS IT TIGHT OR SMOOTH?DOES IT JUMP/SNAP?motor very hot? all bad signs.Change that power head too.The transformers are OK because 1 trans can only run 3 valves max.
Posted on Sep 21, 2010
  • 182 Answers
SOURCE: I have a Weil Mclain
when the boiler goes out does the whole unit shut down or just the burner?
Posted on Dec 20, 2010
We have a W. McLain CG, small house, just 1 zone so no zone valve. How do I get the pressure back up, it is too low and heat is not reaching the back room
Boilers are set at 180 degrees which gives between 550 and 600 degrees per foot of baseboard depending on the brand. You can change the aquastat setting to 200 degrees which will give more heat, but that may not be your problem. Your system may not be balanced properly. If there is too much baseboard(BB) near the thermostat, it may shut down the boiler before it is warm in the back room. You can close the dampers near where the stat is, and fully open the dampers in the cold room. There is also the possibility that you need to purge some air from the system.
The best solution would be to split off with another zone if none of this works. I'm assuming you have a CG-3, but what size is your house? Is there an indirect fired water heater that uses the boiler to heat domestic water? If you have a cg-3 and your house is over 1000 sq feet, then your boiler is undersized. Good luck!
Mar 20, 2017 | Heating & Cooling
Boiler working but no hot water
Pump circulating heated water to the tank? Set the temp adjustment on the tank?
Sep 02, 2014 | Weil-McLain Ultra Plus 40 Indirect Fired...
Operating worcester bosch 240 gas boiler
  1. If there is no water on the floor, your crack is probably OK so far. The water thing is a worry though. NEVER fire a boiler that is low on water. Adding water to a hot boiler will crack it. Tell me all you can on what components you have in the water and gas lines.
Nov 15, 2013 | Weil-McLain Heating & Cooling
Water leaking inside boiler keeps putting out the pilot light
Most likely cracked core.Has low water cut off alarm and auto make up feed been on?Have you been manually adding water?
Feb 18, 2013 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
Have a water leak inside boiler keeps putting pilot light out
Not good at all. Check for a fill level probe/float/sensor that may be acting up causing the unit to over fill, or you may be looking at buying a new boiler.
I have a Weil-McLain hot water boiler for baseboard heat. The system has one circulator pump. The system has 5 zones - 3 work fine and two are not working. All the zone valves and thermostats are...
Sep 20, 2010 | Honeywell (CT62B1015) Baseboard Heater
I've noticed two problems with my heating system, but not sure if they are related. Here's the background - sorry for being so long winded. Background: I have a Weil-Mclain Gold CGi Series 2 (which was...
Two problems, one is a bad thermostat on zone 2. The second is the boiler. The inducer fan energizes causing a pressure switch to engage. This pressure switch energizes the ignitor. If the ignitor does not get hot enough, it will cycle again all over. The cheapest route to take is to check all hoses going from fan housing to pressure switch looking for bad connections or leaks, the second thing to do is to replace your ignitor (time for it anyway).
Jan 05, 2010 | Heating & Cooling
LOW WATER CUTOFF IS CHATTERING ON WEIL MCLAIN BOILER MODEL EVH95. WHEN THE CUTOFF IS TAKEN OUT OF THE CIRCUIT THE BOILER FIRES, BUT WHEN IT IS PUT BACK, IT WILL NOT STAY LIT?
Don't jumper that control out. You likely have some thing going on with the make up water. best i can do with information provided. T
Jun 16, 2009 | Heating & Cooling
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
