Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire side by side
This is the 3rd time the compressor has went out on my fridge. It is only 6 yrs old we just had it replaced 3 yrs ago. The first time was in the first year. What could be causing this to happen? And how can we resolve this problem.
  • 1,073 Answers
There could be a partial restriction in the capiliary line causing higher that normal high side pressure in the system when the compressor is running
have the tech to replace the suction line along with the compressor let them know that this is the third one gone bad
Posted on Apr 26, 2008
I havea Fridgidaire Fridge Mdl#FRS23R4CB5 we had a power surge the items with Protector are fine the fridge how ever is running but will NOT stay cool! Control Board? Condensor HELP fridge is 6 yrs old...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Sep 26, 2010 | Frigidaire FRS23F4C Side by Side...
I have ge side by side model PSS26SGPASS it just thawed out everything in freezer, reading tc in fridge side now, freezer 37 degrees fridge was up to 50 company coming purchased 6 yrs ago help!
I have the exact problem. My unit is 6 years old too - purchased in 2004. I have located, after cleaning the coil under the unit, this is not the source of the real problem. I took the upper cover off which houses the main logic board to find if I flicked the comp relay "compressor" the compressor then turned on. I took amp readings before and after they were .2 without the compressor running and 1.3 with the compressor on. The main board will need to be replaced. Personally I will try to locate the actual relay and replace it on the board if possible.
Sep 17, 2010 | GE Profile PSS29NGS Side by Side...
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
with the unit being that old , the compressor probably whent out the oils inside probably froze up ,,,,, to replace a compressor you are better off replacing the unit it is a major repair
Jan 31, 2010 | Fisher Freezers
Whirlpool side-by-side won't get cold, compressor clicks on-off.
Sounds like the start relay OR the compressor is no good. Have a service tech look at it, because there may be a capacitor in the circuit, which could be dangerous for you to fool with.
May 28, 2009 | Whirlpool Refrigerators
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Frigidaire side/side has had two compressor failures in 3 yrs
Good question. TO give you an idea Id have to know what kind of failures they were.
1 Grounded, shorted, or open windings indicate an electrical problem. This could be caused by external components or power fluctuations. Or a manufacturer defect in the motor.
2 Stuck or not pumping indicate mechanical problems with what could be the compressor its self (again a manufacturer defect) or non defrosting trouble or contaminated refrigerant oil residue from the first compressor.
To me replacing the drier on any compressor and on most all refrigerant related problems is a requirement. This helps eliminate the contamination in most cases. If you purchased a compressor the drier should also be replaced on domestic refrigerators its usually a copper colored piece 4" to 8" long about 1" dia and same size tubes on both ends close to the 1" area. If your not getting this part replaced each time I feel like your not getting quality work done with comon refrigeration practices. And could lead to such a problem.
Back about 15 years ago one of the big appliance manufacturers were making their sealed compressor parts from composite materials that would not hold up in all environments of use. Compressor failures were rampant. I cant say this is the reason but I can say it cant be either.
Mar 09, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire fridge door makes a loud popping sound
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Dec 29, 2008 | Electrolux Frigidaire Professional Series...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Fridge / Freezer no longer cooling F26R4ARS
it could just be the start switch on the side of the compressor. the only way to test that is to replace it. <$20
Jun 29, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
