Pull roller brushes out of bottom.pull off funny looking yellow ends on roller brushes.clean out hair ect. reinstall also good idea to pop out front wheel and clean
You can go to www.iRobot.com . This is the roomba website. You should be able to find replacement parts, customer support, videos or the Roomba product, and more.
When you cleaned your Roomba, did you also clean the wheel wells and outer most edges of the brush brush cartridges? There can be lint, threads, and at my house, cat hair, wrapped around the outermost edges of the brush cartridges.
I hope my suggestions help. If so, please contact Fixya and rate my solution.
Thanks and Good Luck!
I had the identical problem. I cleaned the brush but the problem persisted. I then put in a new brush that was provided in the box and the problem vanished. I have since used the cleaning tool on the old brush and will try and reinstall it to see if my cleaning worked. In any case a new brush will do the job.
Perform the troubleshooting found at the iRobot website: http://tinyurl.com/nh5c8a (I promise that really does go to the right site.) That troubleshooting will enable you to determine exactly what's causing this problem. (The Easy Way: Run the Roomba minus the dustbin and look in the back. Is the brush turning? If not, there's the problem. Give support a call at 1-877-855-8593 and they'll let you know how to replace the necessary part.)
Same thing happened to me. After "cleaning" the brushes and emptying the filter several times, I realized that the brushes were not properly secured. One of the yellow fasteners needed to be pushed closer to the middle nearer to the brushes. It was not secured properly. When I did this it fixed my problem.
Clean the yellow brush bearings. Then run the Roomba without the dustbin, so that you can watch the brush while the unit is cleaning. Is it turning? If not, call customer support. 877-855-8593. Have your Roomba with you; they will want information from it. Good luck.
I was having the same problem. Roomba would run for 30 seconds and then stop. I tried everything -- then I took the small rubber brush out and removed the small nut at the end. It was packed with dust to the point that it could not turn easily. I cleaned it out and now it is working like a champ. I think the automatic shut down was just a sign that there was too much strain to turn the brushes.
