Question about Panasonic Lumix DMC-FS5 Digital Camera
The lense is jammed and the camera says turn off then on but nothing happens the lense is still jammed on my lumix
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 04, 2010
  • 616markent Sep 11, 2010
    Fix 5 worked perfectly thank you !
Suddenly I keep getting the message "please turn camera off and back on again" but nothing happens when I do I just get the message again. I can turn the dial to view pictures but if the dual is turne
did you try to wait several seconds before turning the camera back on?
When it happens again, after turning off the camera please remove the battery for a few seconds and put it in again. then switch on.
If the problem persists goto the repairshop or your dealer.
Dec 23, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
A frozen digital camera
have you tried removing the battery at all?
May 14, 2008 | Cameras
Lumix zs3. Used outdoors, there are times when the
are you using a polarising filter or sunglasses with polarised lenses. if so take them off.
Mar 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Error message remove lense capand press "play" button. The lense cap is not on.
The lens is jammed in, either the unit has had a knock or there is debris (sand/grit) in the unit, been to the beach lately.
Check to see if the lens is sitting level with the front of the camera. Unit will probably need to go in for servicing.
Sep 27, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Camera got dropped now it won't turn on.
The only way to sort it properly is to dismantle and reassemble. Because it has sustained damage you will have to check for any internal damage caused by the drop. Now the lens is jammed open would suggest the guide pins have either come out of their slots preventing movement or something is obstructing them.
Jun 20, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
My lumix DMC-FS3 Camera's lense is jammed
its toast! I really don't have the full answer other than the part the makes the lens go in and out is broken, needs to be replaced however, it costs more than a new one.
Jan 04, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Camera problem
I have a Lumix DMC-TZ1 and my camera is having simular problems. The camera turns on but the buttons don't work. I can not zoom or take pictures. I can turn the auto stabilizing on and can change photo modes by turning the nob. But the menu button, nav buttons are not doing anything. The screen goes on and everything. I have tried removing the battery and nothing happens.
Apr 06, 2008 | Cameras
Lumix TZ3 lens does not open
It is not clear if you are saying whole camera turns off or just screen turns off.
Notice before the camera went bad the lense does not extend in play mode, while it does in record mode. Many cameras have software that automatically turns camera off if lens cannot/fails to extend for some reason. Try to help it extend in record mode before camera turns off.
Feb 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-FS5 Digital Camera Logo
430 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
